Ford Bronco Zone Early Bronco Classic FullSize Broncos: 351/400-m??? - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
351/400-m??? what is this?
#1 User is offline   akbogger907
  • Bronco Newbie
  • View gallery
  • Group: Members
  • Gender:Male
Post icon  Posted 14 June 2009 - 08:23 PM
can anyone really explain to me what this is? i know the 400 is a stroked 351 m. but what is a 351/400-m?
#2 User is offline   muddrivermike
  • Bronco Pimp
  • PipPipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 15 June 2009 - 06:02 AM
The 351m and 400m are the same engine,The only difference between the two are the crankshaft and the tops of the pistons.So if you had a 351modified engine and took a 400m crank and pistons and put them into the 351m it is now a 400m.Everything else on both engines are exactly the same,,,Intake, block,oil pan,accessories,everything else,you wouldnt be able to tell the difference unless you measured the stroke of the crank to see which one is which.. :D
1978 bronco
351 M
Headers
Dual 3 inch exhaust
C6 Trans
Eledbrock intake
600 holley
DUI distributor
9 inch suspension lift
3 inch body lift
Dana 60 rear
Trac loc in rear
44 frt 8 lug
4.56 gears
40 inch Ground hawgs
8000lb warn winch
Road armor bumper
Kayline soft top
Factory roll bar
http://www.mudspace.com/muddrivermike
#3 User is offline   Crude dude
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 15 June 2009 - 10:29 AM
I dont know if this is true or not but I was going to try to build a performance 400 a few months ago and I had a hard time finding pistons for it. I was looking at the compression heights and the pin sizes of pistons when I noticed that the 351 Cleveland had the correct dimensions for a 400 piston. Anyone try this?
1970 Bronco , 1978 Bronco Ranger XLT, 2007 Dodge Cummins 4x4, 2003 4Runner V8 Limited
#4 User is offline   Bronc76
  • Bronco Commander
  • PipPipPipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 15 June 2009 - 11:32 AM
crude- the 351C and 400 have same compression height, but i think the 400 wrist pin is a little larger than the 351C. Have you tried TRW pistons, I think they were installed in the 400 from '71-'82.
#5 User is offline   rednck7736
  • rednck7736
  • PipPipPip
  • Group: Members
  • Gender:Male
  • Interests:1985 Bronco<br />427 Small block<br />Ford SVO turbo swirl alum heads &amp; Crane roller rockers<br />headers and 2 1/2 flowmaster and 3in tips<br />Edelbrock carb. and comp cam<br />Wiend intake<br />C-6 tranny.<br />33x12.50x15 all terains<br /><br />1977 F-150<br />460<br />Lots oh head work,stud mounted rockers and big valves<br />Weind intake holly carb<br />launti cam<br />L&amp;L headers and ladder bars.<br />6in lift<br />35x12.50x15 Mud tires<br />March pully system<br />and a Chrome bare foot gas peddle
Posted 15 June 2009 - 03:45 PM
www.barnetthighperformance.com - He has a huge passion for making these things scream. (492ci Strokers)
www.tmeyerinc.com -
Try these 2wem sites.They should have a lot of use full info on the 400.I have had a 351M with cam 4bbl and headers.Didnt touch anything other than that.But I am Much Happy after I swapped it out for a 460.But those sites should help you out.
1985 Bronco
427 Small block all alum. top end
C6 tranny
208 transfer
9in rear axle
33x12.50 all terrains
future plans 3in lift and lockers and dump the auto for a 5 speed.Thank god for manual trans.I hate autos.They suck ass and rob power.
1977 F-150 4x4
460 (est close to 500hp)
C6
205 transfer
9in rear axle 4.10 gears and a detroit locker
6in lift
l&l headers and ladder bars.
Has single chamber flow masters hooked to the header with turn downs
35in mud tires
Future plans is a front locker and swap the auto for a manual.
Almost forgit.
1996 ranger to run around in and go to work.
#6 User is offline   Crude dude
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 15 June 2009 - 04:48 PM
Not building one anymore. Sold my 78. I just thought that it was a bit of useless info that someone could verify.
#7 User is offline   78BroncHair
  • It's Only Money, Right?
  • PipPipPip
  • Group: Members
  • Gender:Male
  • Interests:78 Bronco 351 4 inch lift 35 inch Mickey thompson MTZ on M/T Classic lock II <br /><br />54 Ford F100 6 inch chop with a 94 Thunderbird rack and pinion <br /><br />55 Ford F100 stock 223 6 cylinder and 3 on the column<br /><br />56 Ford F100 on a hand built chassis with 86 Chevy K5 blazer suspension and axles and a 383 stroker<br /><br />65 Ford Falcon with an 89 mustang HO 302 and a 5 speed<br /><br />
Posted 23 July 2009 - 01:22 AM
Be forewarned this isnt going to help a whole lot: Hot rod magazine did a buildup on a 400 a couple years ago to prove the 400 isnt just a boat anchor motor, As I remember they were using dodge pistons (?) and a bunch of other manufacturer parts and they ended up somewhere in the neighborhood of 400 horse. Anyone else?
78 bronco 4 inch rough country suspension lift, 35 inch M/T MTZ on M/T Classic Lock II wheels, edelbrock intake and 650CFM carb, 351M/C6, work in progress
21 Dodge hot rod 350 small block, 8' rear end, straight axle front end, 40 ford brakes all around, home built
53 Ford F100 stock 223 6 cylinder/ 3 speed overdrive, mild hot rod
95 Dodge 2500 4x4 cummins 5 speed leveling kit/35 BFG A/Ts, fuel plate/injectors/intake/exhaust/turbo coming soon!
56 Ford Country wagon 351c/C4 daily driver
#8 User is offline   ropemansavage
  • Bronco Newbie
  • Group: Members
  • Gender:Male
Posted 23 September 2009 - 03:37 PM
It was actually a comparison to the 400 built and a 460. They used 351 c rods and pistons as well as the 351c heads and intake. It was putting up almost the same numbers as a mildly built 460 and no engine compartment modifications
#9 User is offline   MidnightRaider
  • Bronco Newbie
  • Group: Members
Posted 23 September 2009 - 05:48 PM
Build a 460! L&L products has everything you'll need for mounts and brackets. Easy swap out. Lots of benifits.
Page 1 of 1
Fast Reply
