What pulleys do you guys run on your broncos that didnt come with ps i need some pulleys for my 71 i need a double pulley for my water pump and crank. what can i get them off of¿?
Page 1 of 1
crank and waterpump v belt pulleys
#2
Posted 11 June 2009 - 07:09 PM
check out bcbroncos.com, i think they have the double pulley you're looking for
#3
Posted 11 June 2009 - 08:08 PM
what car(s) can i get a double groove water pump pulley and double groove crank pulley from for my power steering conversion. I was told to use 2 belts on that goes crank to water pump to alternator. And crank to water pump to ps pump. They cant be much more than 6 and a quarter inches
#4
Posted 12 June 2009 - 02:33 AM
On my engine I have one from the crank to water pump to PS pump and one from the crank to alternator.
Fred
Parts replacement is not trouble shooting, replacement follows trouble shooting
Broncos are MPVs not SUVs
Communication: I know you think you know what I said, but what you need to know is, I didn't say what I meant.
Some of my pictures at Supermotors http://www.supermotors.net/212
1983 Full Size Bronco with; Ford 8.8" 3.08:1 Rear; Dana 44 3.08:1 Front; WARN Premium locking hubs; 31x10.5's; NP208; Holley 4160 4bbl; MSD 6AL Ignition; MSD Blaster 2 coil;
1978 Saginaw Pump V-Belt Power Steering;
1984 F150 Dash;
1985 351W HO;
1985 Tilt steering wheel;
1993 Mercury Sable 3G 130 Amp Alternator;
1995 F150 doors;
1995 20 inches of rear portion of the tub;
1996 Bronco tail gate;
1996 Eddie Bower Over Head Console;
1996 Lincoln Mark VIII 4200 CFM Electric Fan;
Headlight harness upgrade; DRLs; Battery relocated to rear; Under hood fuse box vs fusible links; Upgraded wiring for rear window to 10 AWG;
Always under restoration
1984 F150 Dash;
1985 351W HO;
1995 F150 doors;
#5
Posted 16 June 2009 - 01:25 PM
"What pulleys do you guys run on your broncos that didnt come with ps i need some pulleys for my 71 i need a double pulley for my water pump and crank. what can i get them off of?"
Ideally;
-crank pully 2 grove., 3 bolt., 6" OD
-W/P pully 2 grove., 4 bolt., 5 11/16" OD
Most SB Fords would have these I would think..........
Ideally;
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
