Ford Bronco Zone Early Bronco Classic FullSize Broncos: Bad Solenoid??????? - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Bad Solenoid???????
#1 User is offline   scrub
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 31 May 2009 - 09:09 AM
Swapped out the motor in my 76. Went to start it but nothing when u turn the key. Engine will crank and run if u jumper the solenoid and still shut off when u turn the key off. Had no problems prior to the enging swap and the solenoid is newer. Any suggestions besides a bad solenoid? Stuck waiting for parts till monday anyways. Thx
1976 Bronco / 4" Rancho lift / 33x12.5x15 BFG Mud Terrain / 302 - C4 - Dana 20 / Hurst shifter / dual ex with Flow-Pros, custom bumpers, 9000lb Warn winch / Warn Hubs / custom roll cage
#2 User is offline   Bronc76
  • Bronco Commander
  • PipPipPipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 31 May 2009 - 04:19 PM
scrub- even though it is a newer solenoid, i still would put a newer one and see what happens, are the battery terminals tight? how old is starter?
#3 User is offline   scrub
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 31 May 2009 - 05:24 PM
The starter is new and all connections are tight. Everything works fine when you jumper wire the solenoid posts. It just won't go by turning the key.
#4 User is offline   Bronc76
  • Bronco Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 31 May 2009 - 05:52 PM
ignition switch faulty?
#5 User is online   Bully Bob
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Hot women, 4x4'n, flying homebuilts -- or -- a nice Super Cub !
Posted 01 June 2009 - 05:23 AM
With the key in the "RUN" position.,
Try hooking up your voltmeter to "+" on coil.
(Sounds like you do have voltage there.)
Turn key to "START" & watch the meter...., if the voltage goes away., the prob. is likely in the key-switch or the connections to it.
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
#6 User is offline   Steve83
  • Bronco Guru
  • Group: Members
  • Gender:Male
  • Interests:DVDs, MP3s, Broncos, Crown Vics, radio controlled models, home theater, home improvement
Posted 01 June 2009 - 07:17 AM
That's a relay - not a solenoid. This shows the difference.
Posted Image
When you turn the key to START, do you have 12V at the small post on the relay? How about on the relay's metal baseplate?
#7 User is offline   S_bolt19
  • Bronco Commander
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Broncos and hockey are my hobbies, though some say obsessions. I also like to hunt, fish & 'wheel when ever possible.
Posted 01 June 2009 - 07:28 AM
Relay/solenoid, they are the same thing, but on EBs they are called solenoids.
Are your battery cables good? I had a bad ground cable once and it acted the same way. Got new cables & the problem was solved.
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
#8 User is offline   scrub
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 01 June 2009 - 09:48 AM
Changed out the solenoid and still no better. Don't get it. When I pulled the bronco into the garage for the engine swap everything worked fine. The only thing that is different is the negative cable as I used the one from the newer engine. I'll try swapping back to the old one and see if that works. Another thing I noticed is that when u turn the key to crank the engine the stereo lights go out. What does that mean? Grounding out from the ignition switch? Could a wire from the ignition to the solenoid have got broken during the swap? Which wire on the solenoid is the lead from the ignition? There are 3 wires from the pass side harness going to the solenoid. One to the + post and the other 2 to the top posts.
#9 User is offline   BLADE262US
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
  • Interests:Ford there is nothing else =)
Posted 01 June 2009 - 10:36 AM
You should have all small wires that were on the big lug on one side of the relay along with the main power feed from the battery the only thing on the other big lug should be the big wire that goes to the starter motor . There will be the one small wire should be red with a white stripe that connects to the small lug on the solenoid/relay . This one must have 12 volts on it when the key is in the crank position if it does then your set there and the other thing you must look at is the ground for the relay . Most of the starter relays ground through the mounting tab that holds it to the firewall make sure you have a good connection there and there are a few wierd ones that actually have a second small post that was the ground for the coil in the relay look to see if yours is like that . Some had an S by that terminal and that post has 12 volts on it while cranking so do not ground it . More than likely you have a bad ground for the relay . If you put the relay mount against your battery negative and lets say hook up a jumper cable to the positive side and touch it to the small terminal on the solenoid it will click or pull in if you know that you have 12 volts at the small wire and you dont get the click then its a bad ground clean the firewall mounting place and try again .:D
#10 User is offline   Steve83
  • Bronco Guru
  • Group: Members
  • Gender:Male
Posted 01 June 2009 - 10:52 AM
No, they aren't the same; parts stores aren't the authorities on the meanings of words; and eBs are often called "Jeeps" - does that make them the same thing as Jeeps?
Try this site: http://en.wikipedia.org/wiki/Main_Page
#11 User is offline   scrub
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 01 June 2009 - 11:33 AM
Changed out the ground cable and no different. Swapped out the guts of the ignition switch and no different. Have 12volts at the + post of the relay with the positive cable as well as a yellow wire from the harness. There are two small posts on top. The first one has a red/white wire and has no volts. The second post has a brown wire, no volts with key off but 6.6 volts with the key in run position, not cranking. No volts to starter post @ relay at all. Checked the grounding of the relay also and no different. :angry: Also noticed that it makes a clicking noise when u turn the key to run position, not cranking.
This post has been edited by scrub: 01 June 2009 - 11:36 AM
#12 User is offline   BLADE262US
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 01 June 2009 - 12:06 PM
Can you take a pic of your setup there and post it . That solenoid should not pull in when you turn the key to the run position and the wire should have been red with a white stripe for the cranking voltage to the solenoid . Some of the solenoids with 2 post like I stated earlier would have 12 volts on it when the relay pulled in but that should go nowhere when not pulled in definately a wierd situation . Need pics to see exactly what you have . :D
#13 User is offline   scrub
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 01 June 2009 - 12:32 PM
Here's some pics. Don't laugh, I know it's a mess.
Attached thumbnail(s)
  • Attached Image
  • Attached Image
#14 User is offline   BLADE262US
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 01 June 2009 - 12:42 PM
OK try this unhook both those small wires from the solenoid . Take a piece of wire and hook it to the positive battery terminal . Now touch it to one of the small post one it will pull in and the other will do nothing I think whats happening is that brown wire runs to the positive side of the coil and your getting some backfeeding ( possibly ) so whatever small post makes the relay pull in that is the one that you want the red with the blue stripe to go on . I thought sure it was red with a white but this one is definately red with a blue . Let us know :D
#15 User is offline   scrub
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 01 June 2009 - 12:54 PM
Unhooked both wires form top posts. Using jumper wire from +post, left side post cranks engine over ( the one that the red/blue wire was hooked to), right side post nothing happens. Does this mean it's an ignition problem? Obviously not getting the 12V to the relay from key.
#16 User is offline   BLADE262US
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 01 June 2009 - 01:05 PM
Yes that means you are not getting 12 volts from the key but remember that 12 volts goes from the key switch to the neutral safety switch to the solenoid so need to trace it out and see where it stops . :D
#17 User is offline   scrub
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 01 June 2009 - 01:18 PM
It's never had the neutral safety switch hooked up since I got it, but maybe something got knocked around when changing the motor. I'll check it out. Where is it supposed to hook up to the tranny? Or is it hooked to the linkage? The previous owner installed a hurst floor shifter and I assume that's why the neutral safety wire was never hooked up. Maybe a loose wire danglin around somewhere?
#18 User is offline   BLADE262US
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 01 June 2009 - 01:24 PM
There should have been a switch on the linkage side of the tranny probably round and had 4 wires in it 2 for the ignition in your case red with a blue stripe and 2 for the backup lights that should have been black with a purple . The red with a blue must be connected together for it to complete the circuit so your looking for a red with blue wire laying somewhere . My B+M megashifters have a switch in them to hook up the neutral safety so someone may have hooked it up right . Id check there as well . Ill be off for awhile now :D
#19 User is offline   scrub
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 10 June 2009 - 08:45 PM
Never found the source of the problem but it's fixed now. Located the hot wire while cranking on the back of the ignition and ran a new wire out to the relay top post. Works like a charm now. Thanks to everyone for their posts. :D
Page 1 of 1
Fast Reply
