Fuel Pump Pressure Seem to have to much fuel pressure
#1
Posted 24 May 2009 - 04:40 PM
Thomasville, GA.
69' U152
302
Mostly Stock
#2
Posted 24 May 2009 - 06:05 PM
I had a porous float in the carb to my lawnmower. I sank to the bottom and flooded out.
One should always obtain professional advice before attempting a repair or modification.
1990 Tan on Black Eddie Bauer - resides in North Jersey
302 with 33's on 15s E4OD Speedometer corrected trans
Auto hubs with manual transfer case snorkel
#4
Posted 24 May 2009 - 07:10 PM
That's enough to squirt 20 ft. ..!
Your pump is likely correct.
With airhorn off., & COIL un-pluged.., you should be able to crank the eng. & the float/fuel level should remain the same.
Double check your float adj. level via the instructions.
This post has been edited by Bully Bob: 24 May 2009 - 07:11 PM
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
#5
Posted 25 May 2009 - 05:56 PM
Thomasville, GA.
69' U152
302
Mostly Stock
#6
Posted 26 May 2009 - 12:10 AM
Just my 2 cents.
Charlie
#7
Posted 26 May 2009 - 05:25 AM
Assume you have the airhorn (top of carb) off in order to finger things.
How does the needle come out unless the float is not in place.?
Are all the parts there.? Torsion spring., retainer., & of course the needle., clip., & anti-splash washer.
Is the float shaft in place & seated.?
I doubt there's anything wrong with this carb....something's just amiss with this float & needle/seat set-up.
Changing carbs (other than stock) can have it's own set of headaches.
BTW., factory spec is 4-6 PSI
This post has been edited by Bully Bob: 26 May 2009 - 05:27 AM
#8
Posted 26 May 2009 - 04:48 PM
Also the small retaining clip is there just to keep the float from sliding side to side on the shaft.... correct. There is also a small spring that slides on the shaft that does not appear to be doing anything. All of the diagrams I can find do not even show this spring. Thanks again.
Thomasville, GA.
69' U152
302
Mostly Stock
#9
Posted 26 May 2009 - 05:11 PM
the long end goes down.., & the 90'd end slips under the float hinge.
"Also the small retaining clip is there just to keep the float from sliding side to side on the shaft...correct.?"
NO..! & this may be your problem this clamps on the shaft., & locks down behind the seat., between it & the wall.
It's called "float shaft retainer"
Been a while since I worked a 2-V carb. but I think you're now on the road to recovery here...!!
HTH
#10
Posted 26 May 2009 - 06:08 PM
Thomasville, GA.
69' U152
302
Mostly Stock
#11
Posted 27 May 2009 - 05:35 PM
Thomasville, GA.
69' U152
302
Mostly Stock
#12
Posted 27 May 2009 - 06:15 PM
I think you said, a while back, it has an aft. mkt. electronic ignition....?
--- if so ., you can go a bit more in adv.
Have fun with you rig..!
#14
Posted 28 May 2009 - 10:13 AM
Parts replacement is not trouble shooting, replacement follows trouble shooting
Broncos are MPVs not SUVs
Communication: I know you think you know what I said, but what you need to know is, I didn't say what I meant.
Some of my pictures at Supermotors http://www.supermotors.net/212
1983 Full Size Bronco with; Ford 8.8" 3.08:1 Rear; Dana 44 3.08:1 Front; WARN Premium locking hubs; 31x10.5's; NP208; Holley 4160 4bbl; MSD 6AL Ignition; MSD Blaster 2 coil;
1978 Saginaw Pump V-Belt Power Steering;
1984 F150 Dash;
1985 351W HO;
1985 Tilt steering wheel;
1993 Mercury Sable 3G 130 Amp Alternator;
1995 F150 doors;
1995 20 inches of rear portion of the tub;
1996 Bronco tail gate;
1996 Eddie Bower Over Head Console;
1996 Lincoln Mark VIII 4200 CFM Electric Fan;
Headlight harness upgrade; DRLs; Battery relocated to rear; Under hood fuse box vs fusible links; Upgraded wiring for rear window to 10 AWG;
Always under restoration
Sign In
Register
Help
Add Reply
MultiQuote
