Ford Bronco Zone Early Bronco Classic FullSize Broncos: Vent window pin - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Vent window pin
#1 User is offline   cdaye
  • Where's My Hammer!?!
  • Pip
  • Group: Members
Posted 19 May 2009 - 04:01 PM
What's the best way to remove the frame from the vent window so I can install a new pin? The pins on both my vents are rusted thru.
#2 User is offline   Bronc76
  • Bronco Commander
  • PipPipPipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 19 May 2009 - 06:05 PM
same problem here, in the chilton manual it says to remove the window from frame using a special glass and channel tool, its probably best to take them to a body shop, i'm sure they have one. i dont see purchasing a tool that you're use maybe once or twice in a lifetime depending on cost.
#3 User is offline   Steve83
  • Bronco Guru
  • Group: Members
  • Gender:Male
  • Interests:DVDs, MP3s, Broncos, Crown Vics, radio controlled models, home theater, home improvement
Posted 20 May 2009 - 07:22 AM
There's not a 'best' way because there's only 1 way. Take the vent window assembly out of the door & take it apart.
The tool is the equivalent of a sharpened heavy-bladed paint scraper that cuts the bond between the channel & the glass.
#4 User is offline   cdaye
  • Pip
  • Group: Members
Posted 24 May 2009 - 10:39 AM
Thanks.... got it apart. the window setting tape used to put it back in is hard to find, but I found some. Also, the window tape thickness is 1/16"
This post has been edited by cdaye: 02 August 2009 - 04:34 AM
Page 1 of 1
Fast Reply
