Started fixing a 73 bronco that has a 78' 302 with ps. Did the front disc brake swap with a 76 F150 setup. No problem. It had a drivers side waterpump with water hoses running across crossmember. Thought it would be easy to put the correct waterpump and hoses while I replaced the alternator and ps pump. WRONG! It had a 80' alternator bracket and a piece of bottom bracket for the power steering pump tensioner. I now have the correct brackets but where the alternator tensioner attaches, it hits the crankshaft pulley and the waterpump pulley will not clear the crankshaft pulley. I cannot find the correct pulleys anywhere around here, early 302 pulleys are like finding hen's teeth. I have found aluminum pulleys online, but not really interested in spending big money on shiny trinkets for a beater! Any ideas or sources for used pulleys. Thanks
Page 1 of 1
crankshaft and waterpump pulley's
#2
Posted 04 May 2009 - 06:56 PM
"...anywhere around here"
Where might this be..?
Toms & Wildhorses on the left coast......JBG East., & Duffs in Tennessee
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
#4
Posted 04 May 2009 - 08:52 PM
Try
jeffsbroncograveyard.com
tomsbroncoparts.com
tomsbroncoparts.com
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
