Ford Bronco Zone Early Bronco Classic FullSize Broncos: 460 questions - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
460 questions donor info
#1 User is offline   Broncobill78
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • Group: Members
  • Interests:78/79 Broncos<br />4 wheeling in the mud w/the family<br />thinking about a small boat for family use<br />Teaching my boys how to fix, repair &amp; rebuild &amp; being proud that my daughter is just as interested.
Posted 24 April 2009 - 03:05 PM
I'm getting ready to start on another 460 swap and wondered if anyone here had additional info. The last two that I did I used Lincoln engines, First one I picked up a Brand-X swap kit that was just engine mounts & an oil pan. I used the L&L fenderwell headers and redrilled the 351M accessory mounts. After screwing around for a couple months trying to get my belts to run straight I caved in & bought the L&L accessory brackets and was done with it. Second time around I just bought the whole L&L kit.
This time I'm looking at a Ford 460 from a large cube van (don't know what year but it looks like an 80's model). I seem to remember that the first time I did this the oil pan I got had a van part #. What I'm hoping is that this one I spotted will have a rear sump pan that I can use and being a Ford van engine rather than something out of a car I'm hoping that the front accessories will work as-is without needing the L&L brackets. If it'll work then all I need from L&L will be the motor mounts & headers which saves me a lot compared to the whole kit.
Anyone know if this'll work or are the F-truck 460's the only ones that will bolt right in with nothing more than motor mounts & exhaust manifolds ??
Dave
People who say it can't be done should not interrupt the person doing it.
84 Mustang GT (Great car to lose your license with, I recommend it for those trying to do so)
74 Ranchero (429, c6, Currie enterprises 9" w/Mickey Thompson cheater slicks, 1970 Torino shaker hood scoop)
82 Bronco (Canadian truck, kilometer speedo, dual batteries, hi-output heater, dual factory block heaters/etc)
78 Bronco (400, 33" Fun Countries, fastback softtop)
79 Bronco (460, 36" Ground Hawgs, frame-off rebuild)
84 Bronco (bone-stock beater)
73 Bronco (I only had it 2 wks before flipping & crushing it.)
76 F-350 (390, 40" Super Swampers, ugly ugly ugly fire-engine green/yellow cab w/faded purple bed)
78 Bronco (460, 38.5" Ground Hawgs, Dana 60's, boxed frame, frame-off rebuild)
86 Bronco (only truck I've ever had fall thru the ice & just plain disappear. no end of hassles from the ins. co.)
91 Bronco (25th anniversary edition, red w/grey leather everything interior, 31x11.5's)
88 Bronco (33x12.5's)
79 Bronco (Current project, 4" lift w/weenie little pizza cutters)
Looking for 78/79 parts, please let me know if you have one you're parting out.
#2 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
  • Interests:4wd trucks, hunting, fishing, music
Posted 24 April 2009 - 03:28 PM
One of our local fellow broncomaniacs put a 460 in his 79 from a church van E-350, but it was an 88/89 with EFI. Those models work fine, I think only the older car motors with a front sump oil pan will be a problem when swapping into the bronco. there seems to be at least half a dozen different acc bracket set-ups thru the years, even on 80-up motors. But it is possible to convert the Fi back over to a carb, like I did with my 88 F-350 460. This dude's church van motor was converted to propane for awhile, then back to carb. JSM84
1984 Bronco XLT, 460, C-6 AT, Dana60, Sterling 10.25", 36" GYR RT-II's on H1 rims, S&W Racecars 10-pt cage kit, PRP racing seats, tube doors, Herculiner, custom "shaker" assembly.
1988 Bronco Custom, 302 EFI, C-6 AT, Ford 8.8". parting out
1986 Bronco Custom, 300-I6, NP435 4sp, Ford 8.8", new paint
1988 F-350, 4WD, 460 EFI, C-6Dana 60, Sterling 10.25 (donor)
1978 Bronco Custom, 351M, NP435, Currie Ford 9" w/ spool
1979 F-150 4WD, 351M, C-6, 4.10 gears w/ 35" mud tires
Posted Image
#3 User is offline   Broncobill78
  • Supreme Commander
  • Group: Members
Posted 24 April 2009 - 03:47 PM
Well, that's the beauty of this one (for me at least), it's a carb'd engine to begin with. That's why I'm guessing the van is an early/mid year 80's. I hadn't seen it in the yard before *because* it has a nice running carb'd 460. The owner didn't want to put it out with the general population just to see it scavenged for parts so he's been keeping it tucked away & pointed it out to me when I asked. He's asking $400 for it complete. The only downside that I'm seeing is that it's a nice running engine because it's a rebuild, which of course means someone already probably took the bore out to .020". I've been looking around the past few weeks and the only off-the shelf pistons I'm finding are .020" and .080" now of course I can still go .030"(assuming it cleans up with just .010"), .040" or .060" but any one of those sizes will be custom meaning an additional $30 or so per piston. I'd rather not take it out to .080" just to save a couple hundred bucks. I'm just hoping the front dress will work without needing the L&L stuff.
Dave
#4 User is offline   Yardape
  • Supreme Commander
  • View gallery
  • Group: Members
Posted 24 April 2009 - 04:37 PM
One plus with the van accessories is it should have a sag PS pump. If you have the complete donor and keep all the accessories it should work just fine.
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#5 User is offline   BLADE262US
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
  • Interests:Ford there is nothing else =)
Posted 24 April 2009 - 11:31 PM
Ebay is a good place to get rebuild parts I just bought a full set of silvolite pistons and hastings moly rings for my 429 for $50 shipped brand new . :D
#6 User is offline   smittybronco
  • Duck Tape L'fixer :)
  • PipPip
  • Group: Members
  • Gender:Male
Posted 09 May 2009 - 10:02 AM
as far as the motor mounts i have never had to buy new ones for the 460 swap.. i have used the 351m/400 mounts for all my 460 swaps which is around about 5 now...u can reuse the stock manifolds and have someone redo ur exhaust runing it above ur cross member around ur driveshaft...
#7 User is offline   Broncobill78
  • Supreme Commander
  • Group: Members
Posted 09 May 2009 - 12:54 PM
Cool, good to know. Chances are though that I'll still go with the L&L mounts. The first time I pulled this swap I used stock 460 mounts with L&L headers and had problems with the collectors banging against the body mounts. It got so bad I had to notch the passenger side body mount to have enough clearance for the collector. I think the L&L mounts locate the engine a bit lower down to provide clearance for the fenderwell headers. I considered using the stock exhaust manifolds temporarily until I got the headers but both of my previous swaps used Lincoln engines and the manifolds were all wrong. The exit was in the middle & pointed straight down like a block-hugger header. It would have required some custom bent pipes to bolt up to the remains of the stock exhaust on the Bronco. I found a set of truck manifolds and those would have worked because the exit was in the rear and angled down & back instead of straight down but by then I had the cash for the headers. I haven't picked this 460 up yet so I honestly don't know just what the van manifolds look like but I'd really prefer to run a set of fenderwell headers with this one also.
Right now what I'm most concerned with is the front accessories. I'm not getting the alternator with the engine but I *can* have the bracket and I'm getting the Saginaw PS pump & it's bracket. I'm hoping the van setup will work with the Bronco/F-truck engine compartment meaning I won't need to get the brackets from L&L and that will save me some cash. I'm also hoping the van oil pan will work too.
This post has been edited by Broncobill78: 09 May 2009 - 12:55 PM
Dave
#8 User is offline   smittybronco
  • PipPip
  • Group: Members
  • Gender:Male
Posted 10 May 2009 - 03:34 PM
if u ever need to get maifolds or front accessories ive used LTD stuff and it works great...
Page 1 of 1
Fast Reply
