I've finally gotten down to installing the 5.0 mustang motor into my '67. I've got the 50oz flywheel with the vintage bronco tooth count, but I'm not sure how to determine the rotation. If the flywheel has an imbalance, it must go on a certain way. The bolt circle is even, and there is no alignment dowel or pin, so how do I tell which way to install it?
Page 1 of 1
Flywheel Installation... Flywheel Installation
#2
Posted 11 April 2009 - 03:54 PM
the bolt holes arent drilled exactly in spaces it will only go on one way
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
Lund Moonvisor
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
