Hi, first post. I recently purchased a 1978 Bronco with a Rancho lift which I don't know how much lift it is. And it is pretty solid I think that they had a pretty bad fire due to a fuel line blowing up under the hood but the wiring is suprisingly intact. Anyways the reason I am posting, is there a solid way to figure out how much lift is on the bronco like measuring from the fenders to the ground taking into consideration that there are already 31's on it that are pretty small, second is there a good winch bumper made for this year of bronco Ive hunted all over probably not far and wide enough but whatever. I also wanted to know if there was a way to tell what the drive train consists of. I already know it has the 351m/400 a t18 4 speed transmission, and the obvious ford 9" and the dana 44 front but what is the transfer case, and what are the diffs like completely open or limited slip or what. Your help would be greatly appreciated thank you.
Page 1 of 1
New Old Bronco General Information
#2
Posted 09 April 2009 - 04:47 AM
No, there's no set way to tell how much lift it has because the actual amount of lift achieved will vary depending on the condition of the suspension & the type of lift used, particularly with add-a-leafs & rear blocks rather than whole new spring packs. Having said that, I went back to my old police manuals and looked up stock height for a 78/79 which according to the State of Massachusetts should be 21" at the bottom of the door (Mass doesn't use a bumper height law since bumpers can be moved around too easily so altered vehicle height is measured from the bottom of the door or on EB & Jeep type vehicles without doors the top of the rocker panel). Measure what you've got & compare it to a stock 21" height and that should give you a ballpark idea of how much it's been lifted.
As for the winch bumper try http://www.autostyle...warnclassic.htm
To ck your axles jack them up one at a time so that both wheels are off the ground. Spin one tire while observing the other. If the other tire spins in the opposite direction you have an open differential & if it spins in the same direction you have a limited slip.
You have the much coveted NP205 gear driven transfer case.
This post has been edited by Broncobill78: 09 April 2009 - 04:48 AM
Dave
People who say it can't be done should not interrupt the person doing it.
84 Mustang GT (Great car to lose your license with, I recommend it for those trying to do so)
74 Ranchero (429, c6, Currie enterprises 9" w/Mickey Thompson cheater slicks, 1970 Torino shaker hood scoop)
82 Bronco (Canadian truck, kilometer speedo, dual batteries, hi-output heater, dual factory block heaters/etc)
78 Bronco (400, 33" Fun Countries, fastback softtop)
79 Bronco (460, 36" Ground Hawgs, frame-off rebuild)
84 Bronco (bone-stock beater)
73 Bronco (I only had it 2 wks before flipping & crushing it.)
76 F-350 (390, 40" Super Swampers, ugly ugly ugly fire-engine green/yellow cab w/faded purple bed)
78 Bronco (460, 38.5" Ground Hawgs, Dana 60's, boxed frame, frame-off rebuild)
86 Bronco (only truck I've ever had fall thru the ice & just plain disappear. no end of hassles from the ins. co.)
91 Bronco (25th anniversary edition, red w/grey leather everything interior, 31x11.5's)
88 Bronco (33x12.5's)
79 Bronco (Current project, 4" lift w/weenie little pizza cutters)
Looking for 78/79 parts, please let me know if you have one you're parting out.
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
