Ford Bronco Zone Early Bronco Classic FullSize Broncos: D44 Disassembly - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
D44 Disassembly
#1 User is offline   will.koch
  • It's Only Money, Right?
  • PipPipPip
  • Group: Members
Posted 05 April 2009 - 04:19 AM
I am currently breaking down my D44 front axle (disk brakes). I absolutely cannot figure out how to separate the spindle from the knuckle. The book only says it will be very HARD, and gives a short idea on how to, but it doesn't make any sense. Can anybody walk me through how to do this?
#2 User is offline   Bully Bob
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Hot women, 4x4'n, flying homebuilts -- or -- a nice Super Cub !
Posted 06 April 2009 - 07:54 AM
OOPs..,
"Check that"-----My bad..., thought you meant removing the knuckle.
This post has been edited by Bully Bob: 06 April 2009 - 08:12 AM
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
#3 User is offline   S_bolt19
  • Bronco Commander
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Broncos and hockey are my hobbies, though some say obsessions. I also like to hunt, fish & 'wheel when ever possible.
Posted 06 April 2009 - 08:41 AM
The spindle is held on by 5 bolts. You have to completely take the hub apart and I think that your going to use a 9/16 or 5/8 socket. It shouldn't be that difficult to break them loose because they are threaded into the knuckle.....really, it shouldn't take much to get them off of there.
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
#4 User is offline   Yardape
  • Supreme Commander
  • View gallery
  • Group: Members
Posted 06 April 2009 - 05:34 PM
After you remove the spindle bolts, (punch the bolts through the holes) give the spindle a few taps with a rubber mallot.
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#5 User is offline   will.koch
  • PipPipPip
  • Group: Members
Posted 07 April 2009 - 05:20 PM
The nuts are off and I've been tapping away with a rubber mallet, I guess I'm just concerned about the integrity of the spindle to hit it any harder. I had no idea to tap the bolts back through through, that should help quite a bit. Thanks!
#6 User is offline   will.koch
  • PipPipPip
  • Group: Members
Posted 14 April 2009 - 05:11 PM
Alright, nuts off, bolts tapped through (except bottom bolt which can't go all the way through b/c of knuckle)... I have a 3 jaw puller pulling on the dang thing and pushing in on the axle (a 2 ton puller), and I'm pounding on the spindle while the tension is still on.. Annnndddd.... nothing... Can't even get a gap to form (although I hear once a gap forms it'll just pop off). Is it possible somebody actually welded the spindle onto the caliper mount bracket or onto the knuckle??? If not, what is the next step, to heat it up with a torch?? Thanks for the help!
-Will
#7 User is offline   Broncobill78
  • Supreme Commander
  • Group: Members
  • Interests:78/79 Broncos<br />4 wheeling in the mud w/the family<br />thinking about a small boat for family use<br />Teaching my boys how to fix, repair &amp; rebuild &amp; being proud that my daughter is just as interested.
Posted 15 April 2009 - 03:37 AM
Best I can do, hope it helps.
Attached File(s)
Dave
People who say it can't be done should not interrupt the person doing it.
84 Mustang GT (Great car to lose your license with, I recommend it for those trying to do so)
74 Ranchero (429, c6, Currie enterprises 9" w/Mickey Thompson cheater slicks, 1970 Torino shaker hood scoop)
82 Bronco (Canadian truck, kilometer speedo, dual batteries, hi-output heater, dual factory block heaters/etc)
78 Bronco (400, 33" Fun Countries, fastback softtop)
79 Bronco (460, 36" Ground Hawgs, frame-off rebuild)
84 Bronco (bone-stock beater)
73 Bronco (I only had it 2 wks before flipping & crushing it.)
76 F-350 (390, 40" Super Swampers, ugly ugly ugly fire-engine green/yellow cab w/faded purple bed)
78 Bronco (460, 38.5" Ground Hawgs, Dana 60's, boxed frame, frame-off rebuild)
86 Bronco (only truck I've ever had fall thru the ice & just plain disappear. no end of hassles from the ins. co.)
91 Bronco (25th anniversary edition, red w/grey leather everything interior, 31x11.5's)
88 Bronco (33x12.5's)
79 Bronco (Current project, 4" lift w/weenie little pizza cutters)
Looking for 78/79 parts, please let me know if you have one you're parting out.
Page 1 of 1
Fast Reply
2 User(s) are reading this topic
0 members, 2 guests, 0 anonymous users
