Ford Bronco Zone Early Bronco Classic FullSize Broncos: carb fire - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
carb fire
#1 User is offline   71broncrollsport
  • It's Only Money, Right?
  • PipPipPip
  • Group: Members
Posted 22 March 2009 - 07:20 PM
i was tuning my 302 and timed it to 6 degrees and then set my carb mixture it was running perfectly! as i let it idle it all of a sudden dies. i crank it and it wont start so figure its out of gas and fill it up. i fire it back up and its back to running like crap( popping, slow surging and then back firing out the carb and catching on fire) what can this be the carb? its a old 4160 holley and it sat for a long time, could the carb have failed?
#2 User is offline   Bully Bob
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Hot women, 4x4'n, flying homebuilts -- or -- a nice Super Cub !
Posted 22 March 2009 - 07:37 PM
Make sure you locked down the dizzy bolt/clamp.
Double check your timing.
check all ignition wire connections ..(coil, etc.)
Was it runn'n bad B/4 you started the tune-up?
Timing chain may be on its last legs.
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
#3 User is offline   Bronc76
  • Bronco Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 22 March 2009 - 07:39 PM
71- check the timing again, or is in need of adjustment again. Do you know how long it has been sitting?
Page 1 of 1
Fast Reply
