joshwht
I have a small block Ford engine that I am trying to identify what exactly it is. The motor has an Edelbrock Performer 289 intake manifold on it. The bellhousing has 6 bolts. The casting number above the starter is EOAE 3DC 4. There is a tag attached to the motor above where the starter would be that looks to read 3D26. There is another plate attached to the deck above the flywheel. This tag starts off with a circle with the number 1 in it. Following that is Z 2738 511247. T1 is stamped in one head. The number 5 with 80 below it is stamped in the other head. There is a 35 stamped next to the left rear spark plug. On the back behind the ring gear is stamped 20 30 X. I would appreciate any information that could be provided. I have pictures of the motor.
