Ford Bronco Zone Early Bronco Classic FullSize Broncos: 73 Bronco Fuel System - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
73 Bronco Fuel System Need help with return fuel lines.
#1 User is offline   FordRelic
  • Bronco Newbie
  • View blog
  • Group: Members
  • Gender:Male
  • Interests:1973 Ford Bronco
Posted 20 March 2009 - 04:06 PM
1973 Bronco's had a unique fuel systems with return fuel lines from the fuel pump. On my 1973 the fuel tank switch needs to be replaced along with the aux. tank sending unit. However, no after market 1973 reproduction fuel switches and sending units are available with the return fuel lines.
I am considering the following solution; 1) install a return line on a new sending unit, 2) joining the return fuels lines together (aux & rear tank) through a 'T' and bypass the the fuel switch, 3) fuel switch would only have the primary fuel lines. What are the implications of using this solution? Does someone with a 73 Bronco find an alternative solution (ie move to electic fuel pump)?
03-21-09....Thanks for the feedback. The vehicle is stock from bumper to bumper. Under the hood is a 302 married to a C4 transmission. With the introduction of the 1973 Bronco, Ford Motor Company began messing with the emissions by installing return fuel lines and carbon canister.
This post has been edited by FordRelic: 21 March 2009 - 06:46 AM
#2 User is online   Bully Bob
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Hot women, 4x4'n, flying homebuilts -- or -- a nice Super Cub !
Posted 20 March 2009 - 06:35 PM
GEEEESE..!
That rig must have been built in Germany.... :o
Freak'n amazing.....I've not seen such a set-up..?
HOWEVER..., I'm guessing there's a poss. of over flowing a tank with the following;
".....joining the return fuels lines together (aux & rear tank) through a 'T"
I too am int. in seeing the options here. (I know what I'd do)
May want to tell folks what's there., under the hood., etc. for more accurate help. B)
This post has been edited by Bully Bob: 20 March 2009 - 06:43 PM
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
#3 User is offline   S_bolt19
  • Bronco Commander
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Broncos and hockey are my hobbies, though some say obsessions. I also like to hunt, fish & 'wheel when ever possible.
Posted 20 March 2009 - 09:19 PM
the only EBs I have seen with a return to the tanks are EFI conversions. The mechanical pump & carb don't have a way to return fuel to the tanks. I am am a little confused...do you have a stock engine or a fuel injected one?
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
#4 User is offline   76Explorer
  • Bronco Maniac
  • PipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 21 March 2009 - 04:53 PM
I have seen pics of the fuel return setup on another bronco site a few months ago, the owner was also having the same problem as you finding a replacement switch. I'm not sure what his solutions was, but I'll try to find out.
Here it is... http://www.classicbr...turn+fuel+lines
This post has been edited by 76Explorer: 21 March 2009 - 05:05 PM
1976 Explorer Package
302 bored .040 over
C4 Auto W/Dana 20 J
Power Disk Brakes
Power Steering
Power Door Locks
Power Windows
Dana 44 3.50:1 Front
Ford 9" LS BB 3.50:1 Rear
BFG L/T 31x10.5x16s
Deaver 3 1/2" front coils
Deaver 3 1/2" 11 pack rear leafs
Stonecrusher Steering
Click the link below to see my gallery
http://broncozone.co...t...si&img=1589
#5 User is offline   FordRelic
  • Bronco Newbie
  • View blog
  • Group: Members
  • Gender:Male
Posted 21 March 2009 - 06:05 PM
03-21-09........76 Exporer......Thanks for the link! The pictures are of the fuel switch is exactly like mine. Good feedback provided in the responses provided.
#6 User is offline   S_bolt19
  • Bronco Commander
  • View gallery
  • Group: Members
  • Gender:Male
Posted 21 March 2009 - 11:13 PM
Ok, now that I have seen it, I know what it is. I saw a brand new one of those selectors in the box about 2 months ago. The guy who has it owns an EB junkyard with around 80 EBs in it and said it was for a truck with dual tanks. How to fix it? You got me. If you want more info, PM me & I will give you the guy's phone number here in Colo. Springs. He is one of the most knowledgable EB guy I have ever come across, including all the vendors, and could probably tell you how to fix it.
This post has been edited by S_bolt19: 22 March 2009 - 10:21 PM
72 Daily Driver
#7 User is offline   Steve83
  • Bronco Guru
  • Group: Members
  • Gender:Male
  • Interests:DVDs, MP3s, Broncos, Crown Vics, radio controlled models, home theater, home improvement
Posted 25 April 2009 - 03:55 PM
After fighting the '88 tank selector valve that I originally installed on my friend's '75 (with '88 5.0L/AOD), I recently swapped in a pair of common 3-port fuel switching valves from NAPA, and they work perfectly. A flick of the switch on the dash (no cranking on a valve) and he's running on the other tank.
#8 User is offline   FordRelic
  • Bronco Newbie
  • View blog
  • Group: Members
  • Gender:Male
Posted 28 April 2009 - 06:01 PM
Steve83,
Thanks for the feedback. I did check into a 3 port fuel switch as option. NAPA appeared to be the most reasonable in price. I elected to go with a stock 3 port switch that I found from a contact Colorado.
Eric - FordRelic
Page 1 of 1
Fast Reply
