Hay Ken..,
You're on the right track...
"safety" is the key here..!!!
Chock the rear tires (front & back) & lock the e-brake to prevent any poss. movement.
Strong, non wiggley stands are important. The l'il short stands., extended to their max., is not a good idea.
I put my stands under the frame just behind the bow...where it's flat.
With everything lose., & the wheels off..., leave the pumpkin resting on the floor jack. You should be able to lower the whole axle down, get the springs out..., & roll the whole axle forward on the jack.
It's best to do the "C" bushings on both rad. arms at the same time to get them parallel. Set the axel level & use the garage floor as a point for ea. rad. arm to touch at the same time when all the bolts are snug.
HTH
I now see your stands in the pic......what I've done to gain some height, if needed, is to lay down some 4x6's flat to gain the 4" so as not to have to extend the stands to the max. My stands are approx. 17" at their shortest.
All this seems like a struggle the 1st. time....you'll feel good once you get it done.
You may need longer brake lines with a 3.5 lift.
Have fun.....!!!
This post has been edited by Bully Bob: 10 March 2009 - 04:09 PM
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
