Ford Bronco Zone Early Bronco Classic FullSize Broncos: Trucks backfiring - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Trucks backfiring
#1 User is offline   kingbronco
  • Duck Tape L'fixer :)
  • PipPip
  • Group: Members
Posted 03 March 2009 - 10:15 PM
My bronco is backfiring through the carb when i give it full throttle. It sits and idols fine and will rev up with out a problem when its at idol. When i drive down the road its fine but when i go above 3/4 throttle to full throttle it backfires and runs poorly till i back off the gas anybody have any ideas. ( I have the timing set at 8btdc per my emission sticker)
#2 User is offline   Yardape
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
Posted 04 March 2009 - 07:57 AM
Can you give a brief short recent history of your truck? What have you done to it in the last little while. Sounds like a timing issue to me.
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#3 User is offline   white night
  • Bronco Mechanic
  • PipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:hunting 4 wheeling fishing
Posted 04 March 2009 - 08:09 AM
what kinda carb do you have?
Thank you
Jason,
A.K.A THE WHITE NIGHT
95 bronco
add ons not all done yet
*6 inch lift 36 inch super swampers
some motor work done
duel exhaust
hard top and soft top
*body work in progress
BIG CB
* = IN PROGRESS
TRYING TO MAKE IT MY OWN NOT BOUGHT
#4 User is offline   kingbronco
  • PipPip
  • Group: Members
Posted 04 March 2009 - 11:45 AM
The most recent things I've done is i put a edelbrock performer intake and a edelbrock performer 750CFM carborator and I'm about to do plugs wires cap and rotor tomorrow when it decent outside.
#5 User is offline   white night
  • Bronco Mechanic
  • PipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • Gender:Male
Posted 04 March 2009 - 11:50 AM
how long ago did you put the carb on and did you adj your air fuel mix im wondering if you have something out of adj because it runs ok untill you mash on it and you might be over fueling it.....
Thank you
Jason,
95 bronco
duel exhaust
BIG CB
* = IN PROGRESS
#6 User is offline   Bronc76
  • Bronco Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 04 March 2009 - 12:36 PM
you may also want to check for vacuum leaks at carb or intake manifold
#7 User is offline   kingbronco
  • PipPip
  • Group: Members
Posted 04 March 2009 - 09:25 PM
I put the intake and carb on about 3 weeks ago and have been fixing problems since. Edelbrock says the air fuel screws only affect idol so i haven't touched them since i put it on. It does have 110 primary jets and 107 secondary jets which to me sound a little on the large size.
#8 User is offline   white night
  • Bronco Mechanic
  • PipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • Gender:Male
Posted 05 March 2009 - 07:07 AM
i think that you are aver fueling the cylinders and that is your problem if you dont know how to adj your carb i would take it and have it tuned.
Thank you
Jason,
95 bronco
duel exhaust
BIG CB
* = IN PROGRESS
#9 User is offline   Yardape
  • Supreme Commander
  • View gallery
  • Group: Members
Posted 05 March 2009 - 09:26 AM
Edelbrock is very user friendly, unless you got a bad one they are supposed to be tuned and ready right out of the box.
Lund Moonvisor
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#10 User is offline   Yardape
  • Supreme Commander
  • View gallery
  • Group: Members
Posted 05 March 2009 - 09:29 AM
Maybe you could add what size engine you have, any other mods
Lund Moonvisor
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#11 User is offline   kingbronco
  • PipPip
  • Group: Members
Posted 05 March 2009 - 10:06 PM
its a 460 small cam cant really even tell it has one except at idol edelbrock carb and intake and a Jacobs electronic ignition that i hate and wish i could take out it sucks..
#12 User is offline   Yardape
  • Supreme Commander
  • View gallery
  • Group: Members
Posted 06 March 2009 - 12:36 AM
Does your jacobs box have a timing control in it?
Lund Moonvisor
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#13 User is offline   kingbronco
  • PipPip
  • Group: Members
Posted 06 March 2009 - 11:04 AM
No or not that i can see im used to MSD boxes so they might have hid it.
#14 User is offline   kingbronco
  • PipPip
  • Group: Members
Posted 08 March 2009 - 07:35 PM
Problem fixed it was just a simple timing problem.
Page 1 of 1
Fast Reply
