Ford Bronco Zone Early Bronco Classic FullSize Broncos: oil pressure and water temp senders - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
oil pressure and water temp senders where?
#1 User is offline   Red Green Jr
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 25 February 2009 - 02:49 PM
When I bought my 78, it did not include the water temp and oil pressure senders so I dont have a reference for replacement. I bought new ones but I have no idea where they go. Previous posts have told me that oil pressure is located behind the intake manifold and the water temp is on the intake manifold. But when I looked to find the holes, I found way too many to decide which was which. It would be really great if someone could post some pics of where their senders are located. Thanks very much.
1978 bronco ranger xlt
351M, edelbrock performer intake and 600cfm performer carb
newly rebuilt C6, np205
ford 9in rear diff with 31in mud terrains
http://broncograveya...ord_Bronco.html
#2 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 25 February 2009 - 05:39 PM
I've tried doing a quick search online for some pictures for you, but couldn't find any.. If you have a 351/400m engine. The oil pressure sender is located right behind the air intake (closest to the firewall on the block itself) its the only fitting back there. The water temp sensor is right next to the alternator. I I believe it is a little to the left of it. Where the 2 of them are located there is no other holes around them. If this doesn't help let me know, and I will go outside tomorrow evening and take 2 pictures for you.
Mike
1978 Ford Bronco, 351M, Edelbrock cam,600cfm carb, performer 400 intake, headman headers, side pipes. 4 inch. suspension lift.. All wheel drive.
#3 User is offline   Justshootme84
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • Group: Moderators
  • Gender:Male
  • Interests:4wd trucks, hunting, fishing, music
Posted 25 February 2009 - 05:56 PM
Yes, I went to AutoZone's website and entered a search for component information for a 78 Bronco 351M.
No coolant or engine temp sensor was indicated, but it did have a listing for the oil pressure switch:
" Under hood, center, lower engine area, mounted on front driver side of engine "
On the 351W, this is right next to the oil filter. Like Fritz, I'd have to look at the engine to verify this. JSM84
1984 Bronco XLT, 460, C-6 AT, Dana60, Sterling 10.25", 36" GYR RT-II's on H1 rims, S&W Racecars 10-pt cage kit, PRP racing seats, tube doors, Herculiner, custom "shaker" assembly.
1988 Bronco Custom, 302 EFI, C-6 AT, Ford 8.8". parting out
1986 Bronco Custom, 300-I6, NP435 4sp, Ford 8.8", new paint
1988 F-350, 4WD, 460 EFI, C-6Dana 60, Sterling 10.25 (donor)
1978 Bronco Custom, 351M, NP435, Currie Ford 9" w/ spool
1979 F-150 4WD, 351M, C-6, 4.10 gears w/ 35" mud tires
Posted Image
#4 User is offline   Bronc76
  • Bronco Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 25 February 2009 - 07:47 PM
After reading this post, i had to go outside to look because i didnt know where they were. on the 400 the oil pressure is located on back side of intake (fritz was right) under EGR valve. couldnt really see the water temp but i think it is near alt.
#5 User is offline   muddybronco79
  • Where's My Hammer!?!
  • Pip
  • Group: Members
  • Gender:Male
Posted 27 February 2009 - 08:46 AM
looking at the engine from the front, the temp sensor is between the alternator and water pump on the front facing the radiator. or you can pull some of those stupid vaccum lines off the water neck and stick it there in one of those fittings
79 bronco, 400, C6, NP-205, 40" gumbo mudders on stock suspension. soon to be welded 9in rear
#6 User is offline   Red Green Jr
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 01 March 2009 - 04:28 PM
Thanks guys, I found 'em! I was only able to take a picture of the oil pressure sending unit though.
Attached thumbnail(s)
  • Attached Image
#7 User is offline   79Effie400
  • Bronco Newbie
  • Group: Members
Posted 15 March 2009 - 04:05 AM
Thanks for the pic. I have searched my manuals but neither of them show or tell where the sensor is. with your pic I was able to find it immediately. My gauge is acting up pretty bad so it is either the gauge or the sensor ad now i know where to look.
Page 1 of 1
Fast Reply
