Ford Bronco Zone Early Bronco Classic FullSize Broncos: Engine Gaskets - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Engine Gaskets Intake Man. and Water Pump Gaskets
#1 User is offline   TX '73
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 21 February 2009 - 07:43 PM
I need a bit of advice on replacing an intake manifold gasket and a water pump gasket on a stock 302. I don't have my Haynes Manual w/me but I'll review it before starting. Are their certain type of gaskets that are better to use? Also, replacing the water pump gasket/s: is there a pump to plate gasket and a plate to block gasket? Should I replace both while I have it apart? I assumed I only needed to replace the gasket against the block but I think there are 2 and both probably should be R/R'd.
Any procedure tips are also appreciated!
Thanks...
'73 Bronco Ranger
3.5" WH suspension lift
2 barrel carb - 302
gorilla flares
4pt roll bar
flowmaster exhaust
leaky 9in rear
front disc brakes
#2 User is offline   BUCKIN67
  • Where's My Hammer!?!
  • Pip
  • Group: Members
  • Gender:Male
Posted 22 February 2009 - 04:50 AM
Good Morning to you, Im new here but Iw ill offer my advise to ya! I am a ford motor co senior master technician with 22+ years experience and also hold ASE mastership. I definately would recommend to replace both of the water pumep gaskets. As fo the intake......you will get better sealability if you use a graphite based gasket such as ford factory or Fel-Pro. I will let you decide on the end seals yourself. I would just place a 1/4 to 3/8 thick bead of silicone on the end seal area, especially if your gasket set comes with cork. Hope this helped ya,GOD BLESS!!!
Hi there Folk's, my name is Dusty. I am a ford motor co. senior master tech with 23 years as a mechanic with ford. I am also a ASE master with L-1 advanced level cert. I have been broncoing for years!! I own a 1967 bronco wagon, up graded to a 200 cid six, P/S, power brakes. 33 BFG all terrain's,body lift,4.11's w/equa-lock in rear. Copper and Black. Try to get a pic here soon!!
Page 1 of 1
Fast Reply
