Page 1 of 1
shift to the floor
#2
Posted 18 February 2009 - 08:24 PM
broncostuff, on Feb 18 2009, 05:41 PM, said:
I have a 68 with a 302 and 3 on the tree, Id like to switch to a floor shifter, has anybody that has done this have any feed back as to any problems youve run into also what brand shifter did you use, pro's and con
thank you
thank you
Check out JBG or james duff. they should have everything you need to convert to floor without any problems
#3
Posted 18 February 2009 - 08:59 PM
thank you
thank you
Where are you..? Left coast is Toms & Wild horses
Pretty easy 1 banana job... just follow the directions. You'll be glad you did it...!!
I've had both Duffs & Hurst...they both work fine.
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
#4
Posted 19 February 2009 - 01:57 PM
I think that Hurst might possibly make the Duff shifters...ever lay them side by side? They are almost identical. The parts can interchange. What ever you do, don't get the speed shifter or you will be locking the shift rails up all the time. Ask me how I know that one
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
#5
Posted 23 February 2009 - 11:00 AM
Running the Hurst in my 76. Works well. Only beefs- When putting into park u can break a piece of the front housing out in ya slam it to hard. (It's only plastic) Shift pattern can get kinda annoying if shifting from D to R a lot.
1976 Bronco / 4" Rancho lift / 33x12.5x15 BFG Mud Terrain / 302 - C4 - Dana 20 / Hurst shifter / dual ex with Flow-Pros, custom bumpers, 9000lb Warn winch / Warn Hubs / custom roll cage
#7
Posted 24 February 2009 - 03:36 PM
"How is the 200 I6 with the 250 head for power? "
I think that question is directed at me.....
I've had 6 EB's & this is the one I kept., if that tells ya anything..
Flys down the frwy. & always the rig folks try to out do out in the dirt.
However., headers & 456's, I'm sure, come into play as well.
This post has been edited by Bully Bob: 25 February 2009 - 07:40 AM
#8
Posted 26 February 2009 - 10:14 AM
I woudn't balk at taking a 6-banger. Better gas mileage than the V8 and they are bullet proof. You don't have the snap your head acceleration, but why would you want it in an EB...you get the snap your head torque though
72 Daily Driver
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
