Ford Bronco Zone Early Bronco Classic FullSize Broncos: Whats the best donor vehicle for a 5.0 fuel injected? - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Whats the best donor vehicle for a 5.0 fuel injected? Converting from original 302 to modern 5.0
#1 User is offline   alexr88
  • Where's My Hammer!?!
  • Pip
  • Group: Members
Posted 17 February 2009 - 09:47 AM
Hello guys.
Need expert opinions!!
I finally got an EB. :wub::-) started the frame restoration with sand-blasted frame, body work (not painted), original engine back on the bay and the body is back on the frame with 1 inch body lift and no more rust.
My original intentions were to leave all the driveline alone and put it back together. But as many of you I started contemplating some modifications for a better use of my EB. I currently have an option to buy a 1997 Explorer that was rolled over on an off road trip. The truck still runs and it has 5.0 engines with gt40 heads.
Q: Is the explorer a better donor than a mustang?
Q: If I am buying a donor car, what model and year would be ideal to buy for a "eassier/convinient" conversion?
I am trying to get the most out of the donor vehicle (Wiring harness, complete engine accessories, ECU etc..)
Mine is a 72 EB (Original V8 w/ 3 spd) Trying to go Fuel injected, Auto, 4spd off-road toy but also street friendly to show it off on the weekends LOL.. FYI 6k invested and trying to keep it under 15K. Location: El Paso, TX.
#2 User is offline   Yardape
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
Posted 17 February 2009 - 04:53 PM
Ive always known that the explorer has the sought after gt40 heads but I have never heard of anyone being impressed with the power output of an explorer. The 5.0 H.O. in my opinion is way more desireable. The 5.0. H.O. with gt40 heads, now were talking.
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#3 User is offline   S_bolt19
  • Bronco Commander
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Broncos and hockey are my hobbies, though some say obsessions. I also like to hunt, fish & 'wheel when ever possible.
Posted 19 February 2009 - 02:32 PM
yup, thats the ticket. Your ideal donor will be a 89-92-3 (forgetting the exact years right now) Mustang. It is the mass air system and they run the chance of being the HO system. You don't have to stay away from the 87 and older EFI systems, but they are the less desirable speed density system. I have the SD on mine and have never had problems, but the MA/HO setup is an eye opener. I drove a fresh 5.0 rebuild the other day with MA/HO and it was very impressive.
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
#4 User is offline   scrub
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 23 February 2009 - 11:19 AM
The mass ar setup is from 88-93. Good info on fuel injection swap @ fordfuelinjection.com & bronco.com. Just in the process of tearing out the engine & wiring form my 90 mustang doner. Picked up the whole car for 1200. This is where it get tough. Currently i am just ripping out every wire that I can find & labeling all the connections as i go. I know that there are a lot of extra wires that I don't need. Anyone got any suggestions on how to strip down the harness? Also does anybody know how to get @ the computer easily on this year stang? :huh:
This post has been edited by scrub: 23 February 2009 - 11:39 AM
1976 Bronco / 4" Rancho lift / 33x12.5x15 BFG Mud Terrain / 302 - C4 - Dana 20 / Hurst shifter / dual ex with Flow-Pros, custom bumpers, 9000lb Warn winch / Warn Hubs / custom roll cage
#5 User is offline   Steve83
  • Bronco Guru
  • Group: Members
  • Gender:Male
  • Interests:DVDs, MP3s, Broncos, Crown Vics, radio controlled models, home theater, home improvement
Posted 25 April 2009 - 03:58 PM
'99 Explorer/Mountaineer 5.0L MAF OBD-II EDIS, but you may still have to swap a Crown Vic/Mustang intake on to keep it under the hood.
Page 1 of 1
Fast Reply
