Ford Bronco Zone Early Bronco Classic FullSize Broncos: Low Oil Pressure - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Low Oil Pressure
#1 User is offline   Yoder
  • Duck Tape L'fixer :)
  • PipPip
  • View blog
  • Group: Members
Posted 09 February 2009 - 07:13 AM
i have a 79 bronco with a 351m and when its cold it has great oil pressure about 75 but after it warms up to 200 degrees it looses oil pressure to about 25 or less y is this?
#2 User is offline   Johnny Reb
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 09 February 2009 - 02:06 PM
time for a overhaul soon. The bearings are getting worn out. I had a 351 in mine. I put new bearing in it and it ran real guiet--then it would start chattering-then get quiet . I was gonna put them in myself ,but this guy jumped the gun on me and put them in and it pissed me off. So I drove it home parked it, got a 390 and drooped it it. , and I have lived happily ever after. If you have someone doing the work. Make sure they do it right and keep a receipt. Some of the garages will definetly rip you off. Once you take a interest in working on your bronco-you will do the work yourself and know what to do. I ma sure you will catch on fast. Good luck.
#3 User is offline   Seabronc
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • Group: Moderators
  • Gender:Male
Posted 09 February 2009 - 04:39 PM
I've got the same issue, but I have been nursing it along for 2 years now since the engine still runs strong. Last year I was successful with running 20W50 with a quart or two of Lukas all year, but this year it has been quite a bit colder so I'm using 10W40 with Lukas. A good rule of thumb is 10 lbs per 1000 RPM and everything will be fine. I get around 25 lb at 650 RPM and 40 lbs at cruise. As long as you don't hear any associated knocking you should be fine for a while. Like Johny Reb said you are close to a rebuild but you can nurse it along until you are ready to bite the bullet and go for a short block, long block or rebuild it yourself.
Fred
Parts replacement is not trouble shooting, replacement follows trouble shooting
Broncos are MPVs not SUVs
Communication: I know you think you know what I said, but what you need to know is, I didn't say what I meant.
Some of my pictures at Supermotors http://www.supermotors.net/212
1983 Full Size Bronco with; Ford 8.8" 3.08:1 Rear; Dana 44 3.08:1 Front; WARN Premium locking hubs; 31x10.5's; NP208; Holley 4160 4bbl; MSD 6AL Ignition; MSD Blaster 2 coil;
1978 Saginaw Pump V-Belt Power Steering;
1984 F150 Dash;
1985 351W HO;
1985 Tilt steering wheel;
1993 Mercury Sable 3G 130 Amp Alternator;
1995 F150 doors;
1995 20 inches of rear portion of the tub;
1996 Bronco tail gate;
1996 Eddie Bower Over Head Console;
1996 Lincoln Mark VIII 4200 CFM Electric Fan;
Headlight harness upgrade; DRLs; Battery relocated to rear; Under hood fuse box vs fusible links; Upgraded wiring for rear window to 10 AWG;
Always under restoration
#4 User is offline   Yoder
  • PipPip
  • View blog
  • Group: Members
Posted 09 February 2009 - 06:16 PM
ok that was wat i was thinkin thanks alot to all
#5 User is offline   79fordblake
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:I like to mess around with ole Ford trucks and two-cylinder John Deere tractors.
Posted 17 February 2009 - 07:05 PM
You still have plenty of life in your 351, but yes your bearings are worn and it would be a good idea to install new ones. A friend of mine has a 79 Bronco with a 351 and it holds about 7psi or a little less at hot idle, still runs good and runs quiet, no smoke and it still gets hammered daily. May not be smart but it shows the durability of these engines even with very high milage. They say built Ford tough for a reason :lol:
Only The Best Trucks Are Backed Up By The Blue Oval.
79 Bronco, 400, NP205
33x12.50 Mastercraft Courser MT
KC Daylighter Off Road Lights
4barrel Edelbrock Intake, 600cfm manual choke Holley
clear front parking light lenses
79 Pickup, 302, two-wheel drive
Bored .30, Comp 268 Cam
4barrel Edelbrock Intake, 600cfm manual choke Edelbrock
73 F100, 302, two-wheel drive, short wheelbase
All Original 57,111 miles
#6 User is offline   Johnny Reb
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 17 February 2009 - 09:42 PM
That may be true,but sometimes it pays to fix before getting stranded in a bad place. I wouldn,t want to chance mine 30 miles out in the mountains or in heavy traffic when the engine decided to blow . One of mine ,that has the 400 is guiet ,has plenty of power,but the oil pressuer drops alot when it gets warmed.I will re-build it this summer. I myself rebuilt a 390 in my brothers Ford pick-up. It ran quiet, had plenty of power ,but did have high mileage and was leaking oil in numereous places. He drove it in from almost St.Louise . When I tore the engine down. It had 1 (ONE) tooth on the timeing gear and I think 3 rods-had the caps loose on them-I took them off without a wrench. I also put in a timeieng chain on my old ford 292 because it was looseing power. When I got the new chain on and started it up. It sounded like about 6 rods came loose. I re-built that engine -instead of takeing a chance of blowing the block to pieces and it is still running. Oh-it had 285,000 miles on it -never used oil or had never been taken apart--yes Ford made good engines-like alot of makes-and alot of good use comes with maintances. So, think about the conciquences . It could be putting your life or someones elses at risk.Thanks
#7 User is offline   79fordblake
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 18 February 2009 - 06:30 PM
I wasnt meaning he should continue to run it the way it is. Just thought he should know it will more than likely still serve many more years the way it is. Alot of people don't like the 351m/400 so there are lots of block to still be got out of junkyards so its not really a big deal if you blow one up. Im not saying go blow it up though, I treat the 400 in my 79 Bronco like a baby, keep it full of coolant, keep oil and filter changed on schedule, and add a quart of Lucas oil stabilizer everytime I change the oil. I would drive it anywhere if I had to.
My friend on the other hand barely changes or checks oil, hardly ever checks coolant, but the ole 351m is still hanging in there. He isn't very mechanically inclined though so he pretty much ignores the mechanical guages he had me install for him.
Page 1 of 1
Fast Reply
