Ford Bronco Zone Early Bronco Classic FullSize Broncos: engine swap - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
engine swap Gaskets & oil pan
#1 User is offline   scrub
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 06 February 2009 - 01:37 PM
Going to swap in a 5.0EFI into my 76. I have a 90 mustang for a doner. My plan is to pull the wiring & motor and put it on a stand for now. I plan on changing out the rear seal gasket, valve cover gaskets, & oil pan gasket? Is there anything else that can be done while the motor is out? Also will the mustang oil pan clear in the eb? I have 4" of lift but i think there might be clearance issues. Would the stock 302 pan work on the mustang motor? Any issues with oil pump suction or anything?
1976 Bronco / 4" Rancho lift / 33x12.5x15 BFG Mud Terrain / 302 - C4 - Dana 20 / Hurst shifter / dual ex with Flow-Pros, custom bumpers, 9000lb Warn winch / Warn Hubs / custom roll cage
#2 User is offline   S_bolt19
  • Bronco Commander
  • PipPipPipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Broncos and hockey are my hobbies, though some say obsessions. I also like to hunt, fish & 'wheel when ever possible.
Posted 06 February 2009 - 02:23 PM
There shouldn't be any issue using your old pan. A 302 is a 5.0 and vice versa. Is your lift suspension or body? If it is suspension, it will give you more clearance because it lifts the frame & everything, if it is body only, then there might be clearance issues. I have never used a 'stang pan before.
While it is on the stand, you might go over the water pump & thermostat to make sure that they aren't leaking.
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
#3 User is offline   Yardape
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
Posted 06 February 2009 - 02:51 PM
Might be a good time to do the frost plugs. If you change the oil pan be sure you have the correct oil pump pick up tube for that pan. Also another thing to consider, the 5.0 has the oil dipstick in the oil pan whereas the old 302's have them in the timing chain cover.
This post has been edited by Yardape: 06 February 2009 - 02:51 PM
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
Page 1 of 1
Fast Reply
