Ford Bronco Zone Early Bronco Classic FullSize Broncos: Power steering conversion - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Power steering conversion Power steering hoses do not fit??
#1 User is offline   Crude dude
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 05 February 2009 - 07:02 PM
I am converting my manual steering box over to power steering on my 70'. I have done all of the frame mods and now I am installing the steering pump. I have noticed that the steering box and pump are very close to each other. Is this the norm? Also the power steering hoses are either too long or too short depending on how I route them. Does anyone know if I can clock the housing that the hoses go into on the steering box without problems? This would probably fix my problem if I can...
1970 Bronco , 1978 Bronco Ranger XLT, 2007 Dodge Cummins 4x4, 2003 4Runner V8 Limited
#2 User is offline   Crude dude
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 05 February 2009 - 09:58 PM
During research I found it is actually the spool valve that needs to be turned 90 degrees or even 180 degrees. Thanks for any help
#3 User is offline   Yardape
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
Posted 06 February 2009 - 07:47 AM
Thank you for posting your results, thats how we all learn.
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#4 User is offline   Crude dude
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 06 February 2009 - 10:55 AM
Well that wasnt the final result, I just had the name of the actual part wrong. Thought it was the worm gear and it was actually the spool valve. But I did more research (haha) and called Benchworks and they said "no, by turning that you will creat all kinds of problems". So theres my final answer...Thanks again
#5 User is offline   S_bolt19
  • Bronco Commander
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Broncos and hockey are my hobbies, though some say obsessions. I also like to hunt, fish & 'wheel when ever possible.
Posted 06 February 2009 - 02:25 PM
Just curious, but what steering conversion are you using?
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
#6 User is offline   Seabronc
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 06 February 2009 - 04:13 PM
When I did the Saginaw V-belt conversion on my 83 I made my own high pressure hose. I purchased the fittings and hose from a shop that does hydraulic hoses for heavy equipment.
If you are using a Saginaw, check the seat of the high pressure outlet there are two styles. One that has a beveled seat and one that has an "O" ring seat. Mine has a beveled seat as noted by the fitting in the picture and a picture of the two styles.
Attached thumbnail(s)
  • Attached Image
  • Attached Image
  • Attached Image
  • Attached Image
  • Attached Image
Fred
Parts replacement is not trouble shooting, replacement follows trouble shooting
Broncos are MPVs not SUVs
Communication: I know you think you know what I said, but what you need to know is, I didn't say what I meant.
Some of my pictures at Supermotors http://www.supermotors.net/212
1983 Full Size Bronco with; Ford 8.8" 3.08:1 Rear; Dana 44 3.08:1 Front; WARN Premium locking hubs; 31x10.5's; NP208; Holley 4160 4bbl; MSD 6AL Ignition; MSD Blaster 2 coil;
1978 Saginaw Pump V-Belt Power Steering;
1984 F150 Dash;
1985 351W HO;
1985 Tilt steering wheel;
1993 Mercury Sable 3G 130 Amp Alternator;
1995 F150 doors;
1995 20 inches of rear portion of the tub;
1996 Bronco tail gate;
1996 Eddie Bower Over Head Console;
1996 Lincoln Mark VIII 4200 CFM Electric Fan;
Headlight harness upgrade; DRLs; Battery relocated to rear; Under hood fuse box vs fusible links; Upgraded wiring for rear window to 10 AWG;
Always under restoration
#7 User is offline   Crude dude
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 06 February 2009 - 08:18 PM
It is the 78 Bronco box with the 2wd spool valve. Bought it from West Coast Broncos. Nice kit. Have to grind some casting off of the gear box because it hits the bottom of the power steering pump and had a custom hose made today. Should be complete tomorrow.
#8 User is offline   S_bolt19
  • Bronco Commander
  • View gallery
  • Group: Members
  • Gender:Male
Posted 07 February 2009 - 03:11 PM
I haven't seen that conversion in person, but the pictures are sure nice and I have talked to 1 other guy who did it and he was very satisfied. For your problem, if you are still stuck, call Dusty at WCB & have him talk you through it. He is a pretty good guy and will be more than happy to help.
72 Daily Driver
#9 User is offline   Crude dude
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 07 February 2009 - 11:32 PM
They must be busy over there (WCB). I have left them a couple of voicemails and emailed all 3 available email addresses on their web site, still have not gotten a reply. Started calling a few days ago and emailed them 4 days ago. Either way the paint is drying tonight and will bolt it all up tomorrow.
Page 1 of 1
Fast Reply
