Ford Bronco Zone Early Bronco Classic FullSize Broncos: hi low heater - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
hi low heater
#1 User is offline   fordsohc46
  • fordsohc46
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 03 February 2009 - 08:30 PM
i have a 78 bronco and according to chiltons manual the cable on the outside under the hood mounted by where the heater hoses hooks in is the temp hi low blend door cable. no matter what position the controls inside are in this cable never moves. i disconnected the cable and can move the arm and hear the door inside moving but im not even sure what this is supposed to do. i have a hi-lo settingon the control unit inside. does anybody know what this hi low is and where air should blow while its in this position. my heat works but it blows out the floor a little bit in every position. also i am wanting to try to fix my a/c soon and i cant find a wire close to the compressor to plug into it. does anybody know which wire from the control unit should be hot to turn on the a/c clutch?
78 bronco 400 2bbl. stock C-6 trans.
custom alum. interior almost done
95 bronco eddie bauer 5.8l E4OD trans
4" lift kit 31X10.50 A/T tires
#2 User is offline   BroncoJoe19
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 04 February 2009 - 07:05 PM
It seems that this is your problem.
I guess you need to make sure that it is connected to the control lever on the inside, perhpas the cable is rusted or otherwise frozen, and you need to lubricate it and make it slide smoothely within its sheath. OR replace it.
Did I miss something?
BroncoJoe19... I am not a professional mechanic, nor an engineer.
One should always obtain professional advice before attempting a repair or modification.
1990 Tan on Black Eddie Bauer - resides in North Jersey
302 with 33's on 15s E4OD Speedometer corrected trans
Auto hubs with manual transfer case snorkel
#3 User is offline   fordsohc46
  • fordsohc46
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 06 February 2009 - 01:44 PM
thanks 4 the help do u know which wire turns on the ac clutch
Page 1 of 1
Fast Reply
