Recently started loosing fluid between the master and the booster. Is this just a simple gasket replacment? Thanks.
Page 1 of 1
Master Cylinder question.
#2
Posted 04 February 2009 - 08:38 PM
ORF-there should be a diaphragm between the cylinder and booster that keeps an air tight seal, that could be your problem
#3
Posted 06 February 2009 - 01:54 PM
if it is leaking there the master cyl. is bad and if it has ran like that long enough you will need a booster too bc the brake fluid ruins the diaphram in the booster.
you can buy a master cyl. rebuild kit from lmc truck that should have what you need to fix the leak but the booster may be bad also. hope this helps.
This post has been edited by fordsohc46: 06 February 2009 - 01:56 PM
78 bronco 400 2bbl. stock C-6 trans.
custom alum. interior almost done
95 bronco eddie bauer 5.8l E4OD trans
4" lift kit 31X10.50 A/T tires
#4
Posted 07 February 2009 - 08:36 AM
Got a new master cylinder at the parts store for $25. Fortunatly my booster wasn't ruined from the leaky fluid and I got the system bled out and it works like new again. Thanks Bronc76 and Fordsohc46 for your input.
78 Bronco Ranger XLT. 460, 4"Superlift,35-14.50 Boggers, 4.10's, Detroit Locker & True Trac.
#5
Posted 07 February 2009 - 01:47 PM
orf- no problem
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
