Ford Bronco Zone Early Bronco Classic FullSize Broncos: The Dark Horse - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
  • (2 Pages)
  • 1
  • 2
The Dark Horse
#1 User is offline   Miss Kitten
  • Bronco Pimp
  • PipPipPipPipPipPip
  • Group: Members
  • Gender:Female
  • Interests:wheel, wrench repeat
Posted 12 January 2009 - 02:09 PM
Now that my excitement has calmed down to a level that i'm able to type without shaking, i would like to take this opportunity to introduce everyone here to The Dark Horse
There is alot of heritage and history behind this truck so i would like to share that first. This truck was built in 2002 by one of the local 4x4 shops in the Calgary area Modern Motors STILKIN from this site is actually the owner of the shop. When i first saw this truck come together in 2002 it was the reason that i started buying and building Broncos. Shortly after this truck debuted was when i bought my first 79 Bronco. The obsession evolved from there with another 78 Bronco, and then to my 95 that i currently own. All in hopes that one day i was going to be able to build a replica of the "Bogginfreaks Bronco"
Here are the specs of the truck before I let everyone see the pics ;)
1979 Ford Bronco (now named The Dark Horse)
460 bored out to a 466 with a Holley Truck Avenger 770 CFM 4 barrel Carb
C6 Transmission with an 1100 stall
NP205 T-Case
Dana 60 front with Detroit locker and 5:13 gears with Chromoly Axle Shafts and CTM U-Joints
Hydro Assist Steering
14 Bolt Rear with same 5:13 gears and Detroit locker as well
ARB Bumpers Front and Rear
Warn 12,000lb Winches Front and Rear
4 Racing Seats with 5 point harnesses
Custom Interior Roll Cage
44/19.5/16.5 Boggers with Beadlock Rims
4 wheel disc brakes
Custom Soft Top
When the truck was built in 2002 all brand new body pannels were ordered so there isn't a spec of rust on it.
Once my 95 Bronco sells i'll be able to bring The Dark Horse Home!!!
So now that you know the story behind it and the specs here are the pics
Posted Image
Posted Image
Posted Image
Posted Image
This post has been edited by Miss Kitten: 12 January 2009 - 04:46 PM
a forum post should be like a skirt, long enough to cover the subject material but just short enough to keep things interesting
Keep it Safe
Keep it Legal
Keep on Trails
Keep the Privilege
#2 User is offline   Seabronc
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • Group: Moderators
  • Gender:Male
Posted 12 January 2009 - 05:00 PM
Wow :D/ Some people have all the luck :rolleyes:
Fred
Parts replacement is not trouble shooting, replacement follows trouble shooting
Broncos are MPVs not SUVs
Communication: I know you think you know what I said, but what you need to know is, I didn't say what I meant.
Some of my pictures at Supermotors http://www.supermotors.net/212
1983 Full Size Bronco with; Ford 8.8" 3.08:1 Rear; Dana 44 3.08:1 Front; WARN Premium locking hubs; 31x10.5's; NP208; Holley 4160 4bbl; MSD 6AL Ignition; MSD Blaster 2 coil;
1978 Saginaw Pump V-Belt Power Steering;
1984 F150 Dash;
1985 351W HO;
1985 Tilt steering wheel;
1993 Mercury Sable 3G 130 Amp Alternator;
1995 F150 doors;
1995 20 inches of rear portion of the tub;
1996 Bronco tail gate;
1996 Eddie Bower Over Head Console;
1996 Lincoln Mark VIII 4200 CFM Electric Fan;
Headlight harness upgrade; DRLs; Battery relocated to rear; Under hood fuse box vs fusible links; Upgraded wiring for rear window to 10 AWG;
Always under restoration
#3 User is offline   Bronco_Willis
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 12 January 2009 - 05:32 PM
It has inspired me even more now. The look is what I have been aiming for only with an 87. I LOVE his rear roll cage!
#4 User is offline   Miss Kitten
  • Bronco Pimp
  • Group: Members
  • Gender:Female
Posted 12 January 2009 - 05:53 PM
once i get the bronco home i'll take more pics of the cage for you if you'd like. it all ties into the cab as well. gotta love rollover protection ;) :D
Keep it Safe
Keep it Legal
Keep on Trails
Keep the Privilege
#5 User is offline   Yardape
  • Supreme Commander
  • View gallery
  • Group: Members
Posted 12 January 2009 - 06:50 PM
does that mean you can do doughnuts in a field now???
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#6 User is offline   Bronco_Willis
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 12 January 2009 - 07:27 PM
I would really appreciate that!
#7 User is offline   Miss Kitten
  • Bronco Pimp
  • Group: Members
  • Gender:Female
Posted 12 January 2009 - 07:54 PM
hahahah no donuts in a field
crazy not stupid remember ;)
Keep it Safe
Keep it Legal
Keep on Trails
Keep the Privilege
#8 User is offline   79bigbronco
  • Bronco Maniac
  • PipPipPipPipPip
  • Group: Members
  • Interests:wheelin' building & maintaining custom 4x4's, anything to do with 4 wheels & an engine
Posted 12 January 2009 - 09:36 PM
nice to see it again, to many people thought mine was that one, but alas it has outlasted the imfamous junk
Life is like a crap sandwich, the more bread you have, the less crap you have to eat!
Everythings legal man! Just as long as you don't get caught!
79 Bronc! xlt
429 400hp, 4 link, 1/2 doors, 4:10's locked
full cage, 12" lift.
R.I.P.
78bronco custom, 2nd. owner, stock,# matching, except for 6" lift & 35's
#9 User is offline   J&SBroncolvrs
  • It's Only Money, Right?
  • PipPipPip
  • View blog
  • View gallery
  • Group: Members
  • Gender:Male
Posted 13 January 2009 - 11:53 AM
Awesome!
#10 User is offline   Miss Kitten
  • Bronco Pimp
  • Group: Members
  • Gender:Female
Posted 13 January 2009 - 09:53 PM
got flex ?!?!?!
Posted Image
Keep it Safe
Keep it Legal
Keep on Trails
Keep the Privilege
#11 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
  • Interests:4wd trucks, hunting, fishing, music
Posted 13 January 2009 - 10:01 PM
So you're buying this 79 Bronco? Sounds awesome!!! Alot nicer than my 78. Really like the bumpers, may have to ask you about this rig next time we chat!!! randy JSM84
1984 Bronco XLT, 460, C-6 AT, Dana60, Sterling 10.25", 36" GYR RT-II's on H1 rims, S&W Racecars 10-pt cage kit, PRP racing seats, tube doors, Herculiner, custom "shaker" assembly.
1988 Bronco Custom, 302 EFI, C-6 AT, Ford 8.8". parting out
1986 Bronco Custom, 300-I6, NP435 4sp, Ford 8.8", new paint
1988 F-350, 4WD, 460 EFI, C-6Dana 60, Sterling 10.25 (donor)
1978 Bronco Custom, 351M, NP435, Currie Ford 9" w/ spool
1979 F-150 4WD, 351M, C-6, 4.10 gears w/ 35" mud tires
Posted Image
#12 User is offline   Miss Kitten
  • Bronco Pimp
  • Group: Members
  • Gender:Female
Posted 13 January 2009 - 10:02 PM
i have bought it :D
just not bringing her home till the 95 sells. more incentive to sell my other bronco this way
Keep it Safe
Keep it Legal
Keep on Trails
Keep the Privilege
#13 User is offline   Yardape
  • Supreme Commander
  • View gallery
  • Group: Members
Posted 14 January 2009 - 02:25 AM
Thats just sick, defies the rules...... I will be lucky if I can stick my foot under my back tire without the front tire coming off the ground.
Lund Moonvisor
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#14 User is offline   Miss Kitten
  • Bronco Pimp
  • Group: Members
  • Gender:Female
Posted 09 March 2009 - 02:37 PM
so my 95 has not yet sold, but i couldn't wait any longer
look what followed me home on saturday!!!!
ok well not quite home, but to my friend les's shop so we can spend some time going over it
Posted Image
Posted Image
Posted Image
Posted Image
other then the truck having been neglected for the past 3 years there isn't going to be much needed to get it all fixed up and ready to go for trail.
so far we have already changed out the holley 770 carb for a holley 670. completely got rid of the hesitation that the truck had and i believe it's going to work so much better for the type of wheeling that we do. the 770 would have been great if it was still going to be only a mud truck. all of the fender flares have been removed, and the hood latch had to get fixed. we still need to find something to use for an extra power steering fluid resivour to finish getting the steering problems figured out. les has been working on fixing alot of the wiring on the truck that wasn't grounded out properly, so hopefully that will get rid of the draw it had. after taking it for a putt putt drive around by les's house on the weekend too the rear main developed a leak. so i'm sure it'll need a few more miles on it to see how many other seals have dried out.
so for the next few weeks the list is going to include:
resivor for steering so that is fixed
better master kill switch for the power instead of the twist switches under the hood
full fluid and drive train check on levels and cleanliness
trying to fix some of the body damage done from the flop in 06
repainting that god awful red interior (i really really hate red interior)
adding my personal custom touch to the exterior ;)
and finishing the bath on the truck in and out to get rid of 3 yrs of built up dust, dirt and cat hair
This post has been edited by Miss Kitten: 09 March 2009 - 02:38 PM
Keep it Safe
Keep it Legal
Keep on Trails
Keep the Privilege
#15 User is offline   BroncoJoe19
  • Supreme Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 09 March 2009 - 03:51 PM
MIss Kitten,
Good luck with that big black horse!
What an awesum toy!
BroncoJoe19... I am not a professional mechanic, nor an engineer.
One should always obtain professional advice before attempting a repair or modification.
1990 Tan on Black Eddie Bauer - resides in North Jersey
302 with 33's on 15s E4OD Speedometer corrected trans
Auto hubs with manual transfer case snorkel
#16 User is offline   Miss Kitten
  • Bronco Pimp
  • Group: Members
  • Gender:Female
Posted 09 March 2009 - 03:53 PM
thanks joe!!! :D
i'll keep the pics coming for sure as it gets cleaned up and ready to hit the trails
and of course some trail pics too :D
Keep it Safe
Keep it Legal
Keep on Trails
Keep the Privilege
#17 User is offline   white night
  • Bronco Mechanic
  • PipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:hunting 4 wheeling fishing
Posted 10 March 2009 - 11:33 AM
well that sounds like a hell of a truck, and sounds like you will take care of it so have fun and be safe
Thank you
Jason,
A.K.A THE WHITE NIGHT
95 bronco
add ons not all done yet
*6 inch lift 36 inch super swampers
some motor work done
duel exhaust
hard top and soft top
*body work in progress
BIG CB
* = IN PROGRESS
TRYING TO MAKE IT MY OWN NOT BOUGHT
#18 User is offline   American Thunder
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Ford trucks and cars, diesels, battleships, guns
Posted 23 April 2009 - 03:55 PM
You think it's big enough??
That thing is AWESOME.
p.s. ever tried a Race Demon carb? From personal experience, they offer performance and insane throttle response over a standard Holley.(even a worked Holley) Try one. Once you go Race Demon, you never go back. :D
* 1983 Bronco - '95 300 converted to carb with '95 5-speed, 3.55s, 9" rear
* 1978 Bronco - Newly acquired project truck - soon to be 5.9L Cummins powered.
* 1996 EB Bronco - 5.8L auto, 160k miles- The wife's truck.
* 1977 Mustang II - 530hp 332" stroker motor, C4 "mighty mite", 3.10s in a 9" detroit locker
#19 User is offline   Yardape
  • Supreme Commander
  • View gallery
  • Group: Members
Posted 23 April 2009 - 04:11 PM
She has a Holley truck avenger, the only thing better for off road would be an after market fuel injection.
Lund Moonvisor
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#20 User is offline   Miss Kitten
  • Bronco Pimp
  • Group: Members
  • Gender:Female
Posted 05 June 2009 - 02:47 PM
sorry guys i know i haven't been posting much. american thunder thank you so much for the comments, and yardape thanks for jumping in too :)
so before getting to the updates on the dark horse i have officially sold the green bronco. it went to a very good home up where yardape lives. so he's been on the look out for it :)
ok here's some updates for everyone
first run out with the dark horse was spent chasing a wire under the dash that kept catching on fire and i burnt up my front winch. both of those problems have been fixed :D
second run out with the truck and i managed to completely explodicate the front driveshaft (yes explodicate is a word it's a miss kitten word). the truck was a little over flexed with me being a tad heavy on the skinny pedal and i blew up the inner ball on the double cardigan shaft at the top. thanks to mike (deejay) the original owner of the truck he informed me that he had BRAND NEW spare front and rear driveshafts for that truck still so i scooped those in a hurry. he sent them home with his parents from bc. so i put the new shaft in for the last run and we're going to rebuild the other shaft. maybe look at a different design to prevent the same problem in the future
over may long weekend we headed out for a day run and on our way to falls creek the seal out the bottom of the steering box decided it had other plans for the day and it left it's designated location. combiantion of previous owners overheating that box too many times and the leak that we knew it had i guess it was only a matter of time lol. power steering sure can fly when all the pressure is released though. there was fluid all up the drivers side of my truck and all the way back to the rear diff
having that seal go was a blessing in disguise though as once my bf and i got the box off we noticed there are quite a few hairline cracks around all of the bolt holes on the frame. if it was left any longer there could have been some serious bad news coming my way. so now i'll get a new seal put in the box, put everything back together, load it up, take it down to see the super duper fantastic superles, and he's gonna help me out and do some plating on the frame to prevent further problems. once we got the truck down to les's house, we go the frame welded and fixed up, changed out all the seals put everything back together, filled the resivour, fired the truck up and pissed power steering fluid all over the walls and floor of les's shop. this is when we discovered a pin hole in the power steering line. and a really bad flare job where the line comes into the box. so we cut the line back to get rid of the hole and i still need to tear it all apart yet again and get that flare filed down.
and as the finale here are the pics of my new decals. it feels great to finally make the truck my own :D thank you again to cody for helping me put the decals on. it was long over due
Posted Image
Posted Image
Posted Image
Posted Image
and a couple clean pics
Posted Image
Posted Image
i'm patiently (ok not patient at all) waiting to get it back out on the trail again. i know it needs more drive time to get the bugs worked out but god dammit i also want one run where nothing goes wrong lol
Keep it Safe
Keep it Legal
Keep on Trails
Keep the Privilege
  • (2 Pages)
  • 1
  • 2
Fast Reply
