I went to crank my bronco the other day and the batteries were dead. I pushed it off (plus to having a manual) and drove it home to see why the alternator wasn't charging the batteries. It drove rough the way home... I found a bad connection on the alternator's wire to the regulator. I fixed the connection and now when I crank it, it cranks fine but as soon as I let off the starter it dies. I can run it with the starter turning but as soon as i let go of the key it dies. What's wrong? Thanks and happy new year!
Page 1 of 1
Starting problems?? Cranks but wont stay running
#2
Posted 31 December 2008 - 12:12 PM
Turn key to the"run" position...read voltage at + side of coil...should be 6-7 volts.
If "0" then key-switch could be bad or the resistor wire to the coil may be bad... (to name a few)
---Jeep recovery unit---
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
6 EB's (& 11 early Land Cruisers) referbished & sold..
#5
Posted 08 January 2009 - 07:36 AM
Good job John..,
& thanks for reporting the results....that helps others..!! ..
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
