Ford Bronco Zone Early Bronco Classic FullSize Broncos: Detroit Locker - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Detroit Locker broken?
#1 User is offline   walkercreekbronco
  • Bronco Maniac
  • PipPipPipPipPip
  • Group: Members
Posted 14 December 2008 - 07:52 PM
I think I may have busted my Detroit Locker. I didn't think this was possible (I'm only running 33's). I knew I broke the rear u-joint, putting the final nail in the coffin of the factory driveshaft. But when I jacked the rear end up, one tire spun by hand while the other was touching the ground. I could hear a slight ratcheting sound. (I used to be able to change a tire without holding it from spinning as long as the other was still on the ground.)
I haven't taken the third member out yet, but I was curious as to what normally breaks on a Detroit. I thought these were supposed to be bulletproof? Is it fixable, or will I need a whole new unit?
#2 User is offline   walkercreekbronco
  • Bronco Maniac
  • PipPipPipPipPip
  • Group: Members
Posted 15 December 2008 - 08:58 PM
Well, I've pulled the third member out. I cannot find any broken pieces to indicate a bad locker. I just now found Detroit's test procedure online. http://www.eaton.com...128312.pdf(wish I'd thought to look for that BEFORE I pulled the 3rd member, oh well, I found bad wheel bearings).
Is there anything I can look for while the third member is out?
Page 1 of 1
Fast Reply
