Ford Bronco Zone Early Bronco Classic FullSize Broncos: Axle Seal - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Axle Seal Replacing the seal
#1 User is offline   will.koch
  • It's Only Money, Right?
  • PipPipPip
  • Group: Members
Posted 06 December 2008 - 04:54 AM
I am trying to pull the axle seal (Ford 9" with drum brakes) to replace it since I replaced the wheel bearings already. I bought an axle puller that just seems to be a joke at this point b/c it is doing absolutely nothing. I am going "by the book" with my differentials book, but the darn book glazes over this step and simply says either use the axle puller or use the end of your axle (either of which would not work on these seals). Then the book says to use RTV sealant when installing the seal back so I'm thinking thats what the last guy did on this seal, so does that mean I will need to break the seal free of the sealant?
Any help is much appreciated.
#2 User is offline   TANK107
  • Duck Tape L'fixer :)
  • PipPip
  • Group: Members
  • Interests:currently own an 07 Polar White Toyota Yaris and a 1966 Ford Mustang and last but DAMN right not least this beautiful addition, my Bronco
Posted 06 December 2008 - 05:04 AM
from what I know on Diesel trucks, I remove the sealant prior to installing a new gasket then replace the gasket and REseal whatever it needs to be sealed (motor components to headlights basically) hope it helps man, try looking it up online, things are sure to pop up!
IM NEW....... that blue oval continues to be an American icon*
#3 User is offline   Bully Bob
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Hot women, 4x4'n, flying homebuilts -- or -- a nice Super Cub !
Posted 06 December 2008 - 07:37 AM
Will..,
Any prybar or large screwdriver will do. Doesn't matter if you destroy the old seal.
Just be careful not to scratch the seat.
Using sealant helps (when installing new seal) should there already be some scratches.
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
Page 1 of 1
Fast Reply
