Hi I need to put a new clutch in my 67 Bronco 6cyl. My book says that it has a 9 inch clutch. But I haven't found a "9" inch clutch. Grave Yard has them listed for V8s LMC has a 91/16 and Tom's has a 9.25, but you need to grind on the bell housing?? My Hollander's book says that nothing will interchange with my 67. Any thoughts anybody? Thanks
Page 1 of 1
New Clutch
#2
Posted 02 December 2008 - 04:11 PM
Mr. Bye..,
'67 EB I-6 170 had two clutches.
A 9".., & a 9 3/8 HD
The 9" press. plate is marked with a "green" paint daub--the disc is marked with 4pink & 2black springs.
The 9 3/8 HD plate is marked with a "blue" paint daub----& the springs (6) are all gray.
I've seen both at the usual auto parts stores (websites).......I got mine (a re-built) at Pep Boys many yrs. ago....& it's still going strong.
Good Idea to re-surface flywheel as well.
Oddly.., it's prob. easier to pull the eng. to change clutch.
Once all the goodies are un-hooked that '6' comes out in about 30 min.
HTH
HTH
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
