my bronco will not idle. itruns as long as you pad the pedal but cuts off when you let off the gas. any suggestions?
Page 1 of 1
302w/2bbl. carb adjustment?
#2
Posted 30 November 2008 - 07:08 PM
The accelerator pump is working & suppling fuel 'til you stop pumping.
-------- (unclear what "pad" the pedal means) ----
If the adj. screws on the lower front of carb. aren't doing anything..., chances are there's debris in the idle circuit...& poss. in the main jets as well.
This post has been edited by Bully Bob: 01 December 2008 - 07:26 AM
---Jeep recovery unit---
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
6 EB's (& 11 early Land Cruisers) referbished & sold..
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
