ON A 289/302 1968 engine, when installing the mach.fuel pump does the fitting point up or down, I thought they were suppose to point down but it doesnt seem to fit, just wounding if i have the right one??
Page 1 of 1
fuel pump
#2
Posted 24 November 2008 - 02:47 PM
"....does the fitting point up or down, I thought they were suppose to point down"
I believe you're refering to the fuel in/out hose bibs......they should be on the bottom.
There will be pressure on the actuating arm against the cam lobe while installing. (spring load)
(The 66-69 vac operated wipers ran off two tubes pointing up, on top of the fuel pump)
This post has been edited by Bully Bob: 24 November 2008 - 03:14 PM
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
