I've got a 1971 EB that will no longer hold 2nd gear. It leaks too. I can't seem to find anything that ID's it. The kits to rebuild it are for one or the other. The bronco Graveyard's kit info says the RAT is a longer case. Does anyone know what length that is? Also does anyone know where to get new shift forks for either of these?
Page 1 of 1
RAT or RAN? ID
#2
Posted 13 November 2008 - 07:40 AM
"I can't seem to find anything that ID's it."
The ID tag is on the pass. side of the trannie (on a flat spot) (usually pretty dirty area)
"Does anyone know what length that is?"
You didn't say what eng...?? The T-case adaptors are diff. lengths.
RAT/RAN transmissions are on the V/8 --- HEF transmission is on the I-6
RAT T-case adaptor is 8 7/8"---RAN T-case adaptor is 9 3/8"---I-6 adaptor is 6 1/2"
"Also does anyone know where to get new shift forks for either of these?"
Tom's Bronco parts.com in Oregon is close to you. They have everything you need.
541-779-1339
Wild Horses is on the left coast as well....both have trannie exchange programs.
wildhorses4x4.com 209-943-0991
541-779-1339
This post has been edited by Bully Bob: 13 November 2008 - 10:03 AM
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
