This post has been edited by broncodawg: 08 November 2008 - 04:56 PM
Engine Trouble Smoke & Fire
#1
Posted 08 November 2008 - 03:32 PM
351W bored .40 over
Speed Pro Forged Pistons
Eagle H Beam Forged Rods
Crane Billet Roller Rockers
Edlebrock Performer Aluminum Heads
Edlebrock Performer Cam & Lifters
Edlebrock Performer Intake
Edelbrock 750cfm carb
K & N X Stream Filter
Billet Distributor
9.5mm plug wires
Ceramic Shorty Headers
NP435
Twin Stick Dana 20
Power Steering
Centerforce II Clutch
3.5" Suspension Lift
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
15 x 10 Aluminum Wheels
#2
Posted 08 November 2008 - 05:06 PM
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#3
Posted 08 November 2008 - 07:33 PM
31" Tires | 6" Rough Country Suspension Lift | Custom wiring for all aftermarket items
Future Mods: Custom built frame| 35" x 12.5 15
My Bronco Zone Gallery | My Superford Profile
My other car... The home for my other car East Coast Motorsports, not just for sports cars...
#4
Posted 09 November 2008 - 05:52 AM
351 firing order is diff. than 302... just in case.,
Was the dizzy stabbed all the way down & locked..?
Assume timing chain/gears are all new..?
Start over.. TDC # 1 compression stroke, on thru to ea. plug wire location.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
#5
Posted 09 November 2008 - 11:00 AM
Everything is new, the distributor was locked down.
This post has been edited by broncodawg: 09 November 2008 - 11:02 AM
351W bored .40 over
Billet Distributor
9.5mm plug wires
NP435
Twin Stick Dana 20
Power Steering
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
#6
Posted 09 November 2008 - 12:04 PM
Reason for asking.., I've heard of the electronic "boxes" going south....
Did you check for spark..?
#7
Posted 09 November 2008 - 01:47 PM
Assuming everything was installed correctly, sounds like your dizz has been installed out of time. usually if it barks back up through the carb like you described the distributor is out 180 degrees. How long did it run before this happened?
Lund Moonvisor
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#8
Posted 10 November 2008 - 05:57 AM
coughing and shooting smoke. I had to clean the plugs twice after I installed it cause they were fouled. After it ran about a mile it backfired, stalled and would start again for about 5 seconds then stall out again. Now it won't start at all. I don't know much about building engines and had a friend helping me but hes gone back to Iraq and I'm stuck.
http://www.youtube.c...h?v=FKz-8SduZEk
351W bored .40 over
Billet Distributor
9.5mm plug wires
NP435
Twin Stick Dana 20
Power Steering
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
#9
Posted 10 November 2008 - 07:08 AM
1.) 1 backfire thru a holley will destroy the power valve. (there's an anti-backfire kit for that)
2.) Somewhere, back a few posts.., someone mentioned when you cam-up a 351 you need to use the 302 firing order.
I've not re-worked a 351 so this is not my strong suit.
I heard the recording B/4 & something doesn't sound right....hard to tell from that..maybe it's the headers making that sound.
And again.., the placement of the dizzy is pretty critical. And the setting of the advance prior to hooking up any vacuum advance. Do you recall where that timing was set..??
This post has been edited by Bully Bob: 10 November 2008 - 07:16 AM
#10
Posted 10 November 2008 - 08:34 AM
#11
Posted 10 November 2008 - 10:41 AM
351W bored .40 over
Billet Distributor
9.5mm plug wires
NP435
Twin Stick Dana 20
Power Steering
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
#12
Posted 10 November 2008 - 03:50 PM
(sometimes the harmonic bal. has to be changed..., {4 to 3 bolt} & the timing marks are diff.)
865-938-6696
jamesduff.com
#13
Posted 10 November 2008 - 07:54 PM
351W bored .40 over
Billet Distributor
9.5mm plug wires
NP435
Twin Stick Dana 20
Power Steering
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
#14
Posted 10 November 2008 - 10:07 PM
#15
Posted 11 November 2008 - 06:11 AM
351W bored .40 over
Billet Distributor
9.5mm plug wires
NP435
Twin Stick Dana 20
Power Steering
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
#16
Posted 11 November 2008 - 06:21 AM
#17
Posted 11 November 2008 - 06:45 AM
".....carb's too small for the motor "
Naw.., I had the same carb on my 405 chev. big block...worked fine.
"..at least need to change my jets"
Naw.., no mountains in Texas.....(the carb is new right)...? (or re-built..meaning it didn't come out of a cubby-hole in a garage did it..?)
Again.., the power valve may have blown due to the backfiring. That would create flooding condition.
Lastly.., if the carb is old, or used....there's a couple other things that need checking.... or., if you didn't have the fuel properly filtered.
Just noticed this...."still spitting black smoke out of the carb" Is this true, or did you mean out of the tailpipe....?
This post has been edited by Bully Bob: 11 November 2008 - 06:52 AM
#18
Posted 11 November 2008 - 08:41 AM
I have a new 140gph electric fuel pump with a new regualtor. I'm waiting on the pressure guage to come in now so I'm not sure what psi the fuel is being pumped in.
The carb came straight off the built 302 that I had in before I did the swap to the 351. It did fine on that motor but I was running a mechanical fuel pump.
I took the air cleaner off again thois morning and there's a layer of black carbon on the inside of the venturis of the carb
351W bored .40 over
Billet Distributor
9.5mm plug wires
NP435
Twin Stick Dana 20
Power Steering
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
#19
Posted 11 November 2008 - 09:06 AM
The pump came with specifications...i.e. pressure ratings.
(elect. pumps are usually more press. than you need)
The reg. should have settings. I think that carb calls for 4-7 PSI (don't quote me) so you may be overpressurized.
You could un-plug the pump & see if it (the eng.) settles down for a while B/4 it (the eng.) runs out of fuel.
This post has been edited by Bully Bob: 11 November 2008 - 02:05 PM
#20
Posted 17 November 2008 - 02:25 PM
Sign In
Register
Help
Add Reply
MultiQuote
