Ford Bronco Zone Early Bronco Classic FullSize Broncos: Carb Adjustment??? - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Carb Adjustment???
#1 User is offline   ken0275
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 02 November 2008 - 02:18 PM
My 76 Bronco finally made the trip here from South Carolina. I am pretty happy with it so far.
I have discovered a couple of problems, like the leaky aux. tank and the truck runs very very rich.
So is there an easy way to or tried and true method to adjust the factory 2 barrel on the factory 302.
I have receipts from the previous owner and the carb was rebuilt in the last few thousand miles.
I am sorta afraid to mess with it, since all you have to do is tap the key and she fires right up.
But the fumes are terrible and she spits out black water from the tail pipe. I know the water is mostly condensation from sitting. My garage door looks like an abstract painting. Even driving down the road the exhaust is bad.....I feel bad for the cars behind me.
Attached thumbnail(s)
  • Attached Image
76 Bronco with a 302 and 3 on the tree. I bought it on Ebay from South Carolina. So far it seems pretty darn solid. I felt bad about cutting it to install the wheel flairs. In the process of installing a 3 1/2" JBG lift kit and 15 x10 Eagle alloys and Pro-Comp X-terrains tires.
Truck has only 71,000 miles on it and as near as I can figure out I am the third owner. According to receipts truck has spent most of its life in Florida. It was even in the Virgin Islands. The last owner was in the Coast Guard and was stationed there. I have parts receipts from a Napa Store there.
#2 User is offline   oleguy74
  • It's Only Money, Right?
  • PipPipPip
  • Group: Members
Posted 02 November 2008 - 02:27 PM
possible power valve.or just float adj.
#3 User is offline   ken0275
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 02 November 2008 - 02:41 PM
How do you do that????
I am like Sgt. Shultz from Hogan's Heroes........."I know Nothinnnnnnng!!!"
#4 User is online   Seabronc
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • Group: Moderators
  • Gender:Male
Posted 02 November 2008 - 05:56 PM
If you know nothing, and it otherwise is working great, I'd go to someone who knows what he is doing. The other option is to learn about your carb. If it is a Holley then you can get books on the subject and dig in. Assuming you have relatively good mechanical ability, it is possible to bring yourself up to speed. No matter what, correcting the problem may be a bit of tear down and reassembly. Running rich after a rebuild, assuming no major problems exist in the carb, could require changing the jets, float adjustment or like previously stated the power valve may be blown so it would need replacement. With the exception of the float adjustment, you will need to do some disassembly and reassembly.
So what I'm really trying to say is get a local professional opinion first. Unfortunately we are not in your garage to look at it and walk you through the process. Find out which carb it is and then read up on it. It is not all that difficult, but the process is too much to include in a forum post, so first you need to determine what is wrong and then go after that and not, "shot gun" the problem. I don't know how we could do that remotely. We can give you suggestions of what may be the problem but we aren't there to actually see and diagnose it.
Fred
Parts replacement is not trouble shooting, replacement follows trouble shooting
Broncos are MPVs not SUVs
Communication: I know you think you know what I said, but what you need to know is, I didn't say what I meant.
Some of my pictures at Supermotors http://www.supermotors.net/212
1983 Full Size Bronco with; Ford 8.8" 3.08:1 Rear; Dana 44 3.08:1 Front; WARN Premium locking hubs; 31x10.5's; NP208; Holley 4160 4bbl; MSD 6AL Ignition; MSD Blaster 2 coil;
1978 Saginaw Pump V-Belt Power Steering;
1984 F150 Dash;
1985 351W HO;
1985 Tilt steering wheel;
1993 Mercury Sable 3G 130 Amp Alternator;
1995 F150 doors;
1995 20 inches of rear portion of the tub;
1996 Bronco tail gate;
1996 Eddie Bower Over Head Console;
1996 Lincoln Mark VIII 4200 CFM Electric Fan;
Headlight harness upgrade; DRLs; Battery relocated to rear; Under hood fuse box vs fusible links; Upgraded wiring for rear window to 10 AWG;
Always under restoration
#5 User is offline   Bully Bob
  • TOP GUN
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Hot women, 4x4'n, flying homebuilts -- or -- a nice Super Cub !
Posted 03 November 2008 - 07:16 AM
Ditto above.., and.,
"I have receipts from the previous owner and the carb was rebuilt in the last few thousand miles."
Sorry., I would have to question this..... :o
"tried and true method to adjust the factory 2 barrel on the factory 302.?"
Not for what you're experiencing. There's something internally wrong in that carb.
"...she spits out black water from the tail pipe"
Not to scare you., but this is probably/could be early signs of a head gasket failure.
All in all.., a great start...!
BTW..., which one R/U selling...green one or red one...?
This post has been edited by Bully Bob: 03 November 2008 - 01:21 PM
---Jeep recovery unit---
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
6 EB's (& 11 early Land Cruisers) referbished & sold..
#6 User is offline   ken0275
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 03 November 2008 - 04:14 PM
I know a good mechanic and I will let him look at the carb. It only spits the water out while I am warming up the vehicle. It doesn't do it after its warmed up. I figured its just condensation from the drastic temp changes from the day to the evening. I may only start it on the weekend, during the week it sits.
I will be selling the green one. Red/ copper one is the one I just purchased.
How much of a difference does it make to a carb if it was rebuilt in Florida and dialed in there for their humidity and sea level. Now the truck is near Chicago.....Could that make that much of a difference???
I would think that would be the case if the truck came from Colorado......I would assume a truck would need to run richer in higher elevations.
If I have to buy a new carb it will be no big deal.........
#7 User is offline   Bully Bob
  • TOP GUN
  • View gallery
  • Group: Members
  • Gender:Male
Posted 03 November 2008 - 04:49 PM
"How much of a difference does it make to a carb if it was rebuilt in Florida and dialed in there for their humidity and sea level. Now the truck is near Chicago.....Could that make that much of a difference ???"
None..., & there's no "dial-in" for humidity.
Sea-level to approx. 5000 ft. req. one size "jet(s)" ---above req. a smaller jet(s)..as a rule of thumb.
"I would assume a truck would need to run richer in higher elevations."
Actually.., the opposite is true..., the higher up ., the thinner the air., therefore., the carb needs smaller jets to bring the ratio nearer to the req. "17.4 to 1" (or is it 14.7 to 1...?) :wacko:
(BTW.., "jets" are what meters the "fuel" ...not the air.)
This post has been edited by Bully Bob: 04 November 2008 - 06:35 AM
Page 1 of 1
Fast Reply
