How do I know which axle I have? I pulled the right axle shaft, it's a 28 spline, the bearing outside diameter is about 2'' 13/16 (hard to measure still on shaft). The shaft size where outside bearing seats is about 1" 5/16 to 3/8 (no micrometer). I can't find any tag or #'s on the axle housing itself.It's a 73 bronco,and it's the rear axle in question. I forgot to measure the brake drum size.Help!
Page 1 of 1
Rear Axle? How do I know?
#2
Posted 17 October 2008 - 06:28 AM
My jaw dropped when I read 28 spline. But then I saw t was an EB so its all good. Have you removed the "pumpkin" yet? The ID tag should be on one of the bolts holding the pumpkin to the diff housing unless it was not reinstalled during the last service.
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
Lund Moonvisor
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#3
Posted 17 October 2008 - 07:10 AM
If you have 28 splines, it is probably a small bearing 9". Not to worry, they are still a strong axles, but measure the break shoes. 10x2.5 is a small bearing & 11x2 is the big bearing.
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
#4
Posted 17 October 2008 - 09:07 AM
Small & large bearing had 28 spline.
Measure the rectangular bearing plate bolt hole center to center.
The long way...., 3 5/16" is small bearing. 3 1/2" & larger are large bearing
Brake drum is 10" X 2" on small bearing (& on 74-75 large bearing)
All 11" drums are large bearing.
HTH
HTH
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
