Ford Bronco Zone Early Bronco Classic FullSize Broncos: 351W swap issues - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
351W swap issues HELP!!!!!
#1 User is offline   broncodawg
  • Broncodawg
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Georgia football, Madden on PS3, huntin', fishin' and dirt bikes
Posted 02 October 2008 - 05:05 AM
I am still in the process of doing my 351W swap and I am having some issues. Can anyone give me some advice?
1. I bought a Summit Racing bracket racer harmonic balancer and a Super Kooler aluminum water pump. The new damper won't clear the bottom of the water pump. I had to reuse the stock damper and with all of my upgrades I wanted the stouter one.
2. My shorty header on the passenger side sits right on the frame rail, and is causing issues with my clutch linkage from my NP435.
3. My crank pulley is is rubbing on the water pump also. Do they make a smaller crank pulley? Won't this be the opposite of underdrive pulleys? or will underdrive pulleys be smaller than stock?
4. Can I notch the frame rail on the passender side to run the dual exhaust? Will this seriously affect the structural integrity of the vehicle?
5.My motor mount holes aren't lining up properly with the 351w. I thought they were identical to the 302?
If anyone can help I'd really appreciate it. I want to get it running again this weekend and I have all this detail stuff to figure ot.
I could have sworn the 351W was an almost identical engine to the 302 other than the deck height and would bolt right in.
71 Bronco
351W bored .40 over
Speed Pro Forged Pistons
Eagle H Beam Forged Rods
Crane Billet Roller Rockers
Edlebrock Performer Aluminum Heads
Edlebrock Performer Cam & Lifters
Edlebrock Performer Intake
Edelbrock 750cfm carb
K & N X Stream Filter
Billet Distributor
9.5mm plug wires
Ceramic Shorty Headers
NP435
Twin Stick Dana 20
Power Steering
Centerforce II Clutch
3.5" Suspension Lift
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
15 x 10 Aluminum Wheels
#2 User is offline   yusuebronko2_86
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
  • Interests:fixin' cars, buildin' models, shoot'n stuff at my friend's ranch, and raisin' all kinds a' hell
Posted 02 October 2008 - 09:23 AM
notch for the exhaust, box frame with 1/4" plate on both sides of the notch (on the open end of the rail of course). it's not expensive (like 40$) to get 351 mounts, best bet.
No matter what happens, or how long it takes,
I'll still be ridin' my horse to the ends of the earth.
#3 User is offline   broncodawg
  • Broncodawg
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 03 October 2008 - 05:01 AM
Thanks. I ordred a smaller damper from Tom's Bronco parts, which is where i got the water pump. They say this should solve my clearance issues on both the damper and the crank pulley. A friend of mine that works on the EDM machine here at our plant is fabricating a new bracket to relocate the clutch linkage and he says we can fix the motor mount issue also.
71 Bronco
351W bored .40 over
Billet Distributor
9.5mm plug wires
NP435
Twin Stick Dana 20
Power Steering
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
#4 User is offline   broncodawg
  • Broncodawg
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Post icon  Posted 08 October 2008 - 11:56 AM
I'm still having issues with the clutch linkage being right on the collector for my drivers side shorty header. My buddy thinks I should swap in a hydraulic clutch set up. Anyone here ever done that with an NP435 on an EB? Anyone doen that at all? Help please. This is the only thing holding me back from getting it running again. Thanks
71 Bronco
351W bored .40 over
Billet Distributor
9.5mm plug wires
NP435
Twin Stick Dana 20
Power Steering
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
#5 User is offline   TX '73
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 09 October 2008 - 04:10 PM
Can you remove the header - heat and bend the tubes toward the fender and reinstall? Or would we be talking about a MAJOR bend?
'73 Bronco Ranger
3.5" WH suspension lift
2 barrel carb - 302
gorilla flares
4pt roll bar
flowmaster exhaust
leaky 9in rear
front disc brakes
#6 User is offline   broncodawg
  • Broncodawg
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Post icon  Posted 09 October 2008 - 05:23 PM
I've got shorty headers. (see pic) Can I really bend them, even with heat?
Attached thumbnail(s)
  • Attached Image
71 Bronco
351W bored .40 over
Billet Distributor
9.5mm plug wires
NP435
Twin Stick Dana 20
Power Steering
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
#7 User is offline   youngcountryhillbilly
  • Bronco Newbie
  • View blog
  • View gallery
  • Group: Members
  • Gender:Male
Posted 16 October 2008 - 07:37 AM
i dont know if this will be of any help...
i installed a 351 w in my 72 sport the 351 and the 302 are the same as for bolt paterns.
1- if you use the 302 front timing chain cover & water pump it should eliminate your harmonic balencer isues..
as well as the isues with the power steering pump and alternator having a wider profile with the windsor front assy your power steering pump pully is verry close to your steering box and you will have to purchase a new radiator with the suply and return ports reversed.. useing the stock 302 front assy eliminates alot of issues and a trip to the nut house.
the motor mounts are the same on the w and 302.. if you have cammed your w you will need to use the 302 firing order..
i actualy made a rod for my clutch assy with a bend to go around my exaust it has 2 bends it is droped an inch from where it atatches to the pivot arm and then it is shaped like a bow with a threaded adjustment tube instead of the standerd slip tube with a lock nut... hope this might be of some help...
#8 User is offline   broncodawg
  • Broncodawg
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 16 October 2008 - 12:43 PM
Thanks. That put me over the top. The clutch linkage was my last problem. i switched to the stock water pump/timing cover this past Sunday and put the damper and aluminum water pump on ebay. I appreciate the help.
71 Bronco
351W bored .40 over
Billet Distributor
9.5mm plug wires
NP435
Twin Stick Dana 20
Power Steering
2" Body Lift
4.56 gears
35 x 12.5 Mud Kings
#9 User is offline   Go Tac
  • It's Only Money, Right?
  • PipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Drag racing, boating, camping, hunting, family & friends.
Posted 05 January 2009 - 06:51 AM
I ran across some info on the hydraulic clutch. Also do a "hydraulic clutch" search here on the site. Hope this helps.
http://classicbronco...licclutch.shtml
Page 1 of 1
Fast Reply
