Ford Bronco Zone Early Bronco Classic FullSize Broncos: Using a -79 9" for my hotrod - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
#1 User is offline   Eriksson
  • Bronco Newbie
  • Group: Members
Posted 20 September 2008 - 12:33 AM
Hello guys!
First of all, im from sweden, but iīll do my best to make me understood..
Im building a ford 32 Roadster and im going to use a rear axle from a -79 bronco (9" , 31 splines)
on my axle the "housing" isnīt centerd, proably because it comes of a 4x4? so the right driveshaft needs to be shortened about 4 inches/10cm (or changed)
So, my question is: how long are the left and right driveshafts? i was hoping i maybe could use two lefties.
Best regards
Martin
edit: i dont even know if itīs called driveshafts.. i hope you understand what i mean.
Attached thumbnail(s)
  • Attached Image
This post has been edited by Eriksson: 20 September 2008 - 12:35 AM
#2 User is offline   Yardape
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
Posted 20 September 2008 - 05:16 AM
I'm unsure of the measuremrnts but what you are talking about are called axle shafts. You were close. Should be very nice when you are done
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#3 User is offline   S_bolt19
  • Bronco Commander
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Broncos and hockey are my hobbies, though some say obsessions. I also like to hunt, fish & 'wheel when ever possible.
Posted 22 September 2008 - 10:27 AM
That rear end should be centered from the get go. Did someone altered it to begin with? I would imagine that if you are putting that axle under a roadster it would need to be cut down anyway because the FSB is quite a bit wider than your 32 is. I know on the Early Broncos the axle width is 56" and the 9" does have one short axle, but that is for the spider gears inside of the housing. One axle shaft will go in further than the other because the gear cluster is offset, but the housing it'self should be centered.
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
Page 1 of 1
Fast Reply
