Interior Spare Tire Carrier
vincendebbie
vincendebbie
Covington, La.
Hey I know this sounds crazy but I need someone to post or send me a pic of a properly installed interior spare tire holder. I finally got my parts truck here and want to move my spare inside but need to know the placement before I start moving things over. Oh and I also need the bracket. I will visit the wanted section for that. Thanks, Vince.
e-mail: [email protected]
Here are your pictures. The first one shows the location it is supposed top be in. There are usually pre-drilled holes with weld nuts already in position for the large bolts. It uses bolts similar to the ones that hold the seat belts but with no collar. The second is with it mounted with trim panels in place, ditto for the third. fourth with tire mounted. Cover in place
vincendebbie
vincendebbie
vincendebbie
Covington, La.
I appreciate it Seabronc. I was trying to decide if I wanted to eliminate the weight on the out side panels of the truck or not. Now all I have to do is find the complete bracket. Again I appreciate it. You can close this thread now. Thanks, Vince
Wihill
