Ford Bronco Zone Early Bronco Classic FullSize Broncos: no spark - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
no spark tried everything
#1 User is offline   Red Green Jr
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 01 September 2008 - 01:12 PM
My bronco has been sitting for most of the summer with occasional use on the weekends only. One weekend, I tried to start it and it just wouldn't fire. After a while I tested the spark, and there was none. The distributor and coil were only a few months old and have been working great. Since the problem started I have replaced the voltage regulator, ignition module and the starter, I have tested all of the wiring to the coil and made sure that power is getting to the ignition module. When I was testing voltage to the ignition module, I got 12V when the key was turned to "on", but when I started cranking, the voltage dropped to 0.4V, which is obviously not enough to make a spark. The only possible candidates left are a bad ignition switch, or some other system is tied into the ignition and is sucking all the voltage. Other than that I have no idea what the problem is and am running out of patience.
thanks
This post has been edited by Red Green Jr: 01 September 2008 - 01:17 PM
1978 bronco ranger xlt
351M, edelbrock performer intake and 600cfm performer carb
newly rebuilt C6, np205
ford 9in rear diff with 31in mud terrains
http://broncograveya...ord_Bronco.html
#2 User is offline   Seabronc
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • Group: Moderators
  • Gender:Male
Posted 01 September 2008 - 07:37 PM
What ignition system do you have installed in it? Is it a Duraspark II? If that is the case then the pickup coil inside the distributor is bad. If it is a Duraspark II then I can upload you a diagram and troubleshooting procedure.
Fred
Parts replacement is not trouble shooting, replacement follows trouble shooting
Broncos are MPVs not SUVs
Communication: I know you think you know what I said, but what you need to know is, I didn't say what I meant.
Some of my pictures at Supermotors http://www.supermotors.net/212
1983 Full Size Bronco with; Ford 8.8" 3.08:1 Rear; Dana 44 3.08:1 Front; WARN Premium locking hubs; 31x10.5's; NP208; Holley 4160 4bbl; MSD 6AL Ignition; MSD Blaster 2 coil;
1978 Saginaw Pump V-Belt Power Steering;
1984 F150 Dash;
1985 351W HO;
1985 Tilt steering wheel;
1993 Mercury Sable 3G 130 Amp Alternator;
1995 F150 doors;
1995 20 inches of rear portion of the tub;
1996 Bronco tail gate;
1996 Eddie Bower Over Head Console;
1996 Lincoln Mark VIII 4200 CFM Electric Fan;
Headlight harness upgrade; DRLs; Battery relocated to rear; Under hood fuse box vs fusible links; Upgraded wiring for rear window to 10 AWG;
Always under restoration
#3 User is offline   Red Green Jr
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 02 September 2008 - 12:35 PM
Its a duraspark, I have no idea if its a duraspark II or what. Is there a difference?
#4 User is offline   Seabronc
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 03 September 2008 - 03:16 AM
It probably is. Here are the diagrams and proceedure.
Attached thumbnail(s)
  • Attached Image
  • Attached Image
  • Attached Image
  • Attached Image
  • Attached Image
  • Attached Image
Fred
1984 F150 Dash;
1985 351W HO;
1995 F150 doors;
#5 User is offline   Red Green Jr
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 04 September 2008 - 09:10 AM
Thanks a lot!
This post has been edited by Red Green Jr: 07 September 2008 - 05:18 PM
#6 User is offline   Red Green Jr
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 07 September 2008 - 05:36 PM
After more work, i still have not solved the problem. I had a few possible solutions, but none of them worked. I replaced the ignition switch too. Just this weekend, one of the wires popped out of the pigtail leading from the ignition module. I am getting a new pigtail and hoping that that was the problem. I had tested continuity in the wires before and it looked good, but old, corroded wires can be very flaky. Any more info would be greatly appreciated. thanks
#7 User is offline   Red Green Jr
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 17 September 2008 - 01:05 PM
she lives!!! turns out it was the pigtail leading from the ignition module to the coil. i had checked it before and it passed but i guess it disconnected when i plugged it back in. so thats $83 of replacing working components and an $8 fix, aint life grand.
Page 1 of 1
Fast Reply
