Ford Bronco Zone Early Bronco Classic FullSize Broncos: I desprately need help with front end - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
#1 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 03 August 2008 - 04:00 PM
ok I need some help. I have a bad front end shimmy between 60-70mph. I had the tires balanced, and I just replaced the sway bar end link bushings and the sway bar bushings. I also replaced the trac arm bushings this morning. I know I need a steering stabilizer and a steering gearbox, but I'm really tight on money. Does anyone have any clues or suggestions on what can be causing this front end to shake as bad as it does? I could really use the help.
Thanks
Mike
1978 Ford Bronco, 351M, Edelbrock cam,600cfm carb, performer 400 intake, headman headers, side pipes. 4 inch. suspension lift.. All wheel drive.
#2 User is offline   swampthing
  • Bronco Commander
  • PipPipPipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:I drive an 85 bronco with 4 inch (soon to be 6 inch lift) it has a worked 302, msd ignition components, ford performance racing cam and lifters, ford racing intake, holley dual feed mech. secondady carb, custom dual exhaust, 2 1/2 inch dynomax oval bullit race mufflers with hollowed cats, <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=24&k=5%20point%20harness" onmouseover="window.status='5 point harness'; return true;" onmouseout="window.status=''; return true;">5 point harness</a>, supertach, water temp and oil pressure guages.
Posted 03 August 2008 - 06:18 PM
could be stabilizer causing it...also check your balljoints
currently: 78 bronco 400M c6 np205 d44 9 inch cut wells 38 inch tsls no interior soft top summit headers dual flowtech exhaust
built : 85 bronco, locked rear 302 fpr intake cam push rods and lifters, comp cam springs, ported heads and intake 4 inch lift c6 33 inch tsls
78 bronco 400M jasper open front and rear S/A 9 inch 4 inch lift 36 inch kelly safaris holley red holley regulator
88 ford F250 stock 302 EFI AOD with shift kit. d60 back 4.11 d44 TTB front 4.11 36 inch goodyear wrangler R/T II's
#3 User is offline   Yardape
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
Posted 03 August 2008 - 07:42 PM
Does it shake in 2 wheel drive? are you sure the hubs are both unlocked? How are the tires? Check the pressure, look for seperated belts. Uneven wear. Check Balljoints. Send it in for an alignment, if there is any front end damage they will print you out a sheet of everything that needs to be fixed before they will align it.
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#4 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 03 August 2008 - 07:49 PM
I haven't check the ball joints. How would I go about doing so? The truck is all wheel drive so I can't lock or unlock the hubs. Would the bad steering gearbox cause a problem with the alignment? I checked the tires earlier and it seems that the outside edges of them are eaten a little bit. and they are at 35psi. They are 33inch tires, nothing big. I am going to order a stabilizer from broncograveyard either tomorrow or thursday when I get paid. On there they are only 40$.
Thanks for the replies
Mike.
#5 User is offline   Yardape
  • Supreme Commander
  • View gallery
  • Group: Members
Posted 03 August 2008 - 07:56 PM
Jack up one side at a time and grab your front tire, one hand at 6 oclock and one at 12. and try and wiggle the tire if there is any movement that is bad. Could be the balljoints or your wheel bearings. I your tires are getting eaten up I would suspect your Balljoints are getting worn out. Is your Bronco factory all wheel drive? Thats the first I have ever heard of that in a Bronc. Hmm learn something new everyday
Lund Moonvisor
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#6 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 04 August 2008 - 08:25 AM
yes the bronco is factory all wheel drive. I've tried moving the wheels before while up in the air and there is no movement.
#7 User is offline   HardMaple
  • It's Only Money, Right?
  • PipPipPip
  • Group: Members
  • Gender:Male
Posted 05 August 2008 - 07:09 AM
I'm not here to turn this into a flame thread full of arguments and this is the only thing I will say on the subject.
No Bronco is factory all wheel drive. Period. Some are manual hubs, some are automatic hubs, but all Broncos leave the factory as 4x4s.
If yours is in fact AWD, someone converted along the way. But I think what we have is a misunderstanding of what you call AWD.
1996 Bronco 5.0L
No mods
Recently purchased and trying to get it ready for hunting season
My political blog
#8 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 05 August 2008 - 12:57 PM
This isn't the first time I have heard someone say this, and someone told me this I wouldn't believe them either. The reason I say it is all wheel drive is because the shifter handle doesn't say 2wheel drive on it anywhere and I don't have the option to lock or unlock the front wheels. If you have any other input please let me know because I'd like to know. and the person that had it before me was the original owner that did nothing with the truck, she used it for normal driving use. I'm going to try to attach a picture of the shifter know. Let me know what you think.
Attached thumbnail(s)
  • Attached Image
#9 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
  • Interests:4wd trucks, hunting, fishing, music
Posted 06 August 2008 - 05:06 PM
That is the "FULLTIME" 4WD with a NewProcess 203 transfer case. Might be considered "ALLWHEEL Drive", since both driveshafts are always turning. both diffs in the axles. I doubt though that it would cause a shimmy or alignment problem. AS stated, suspect items are the balljoints, wheel bearings, tie rod ends and steering linkage. Is ther any play in the steering wheel? I've seen the stock or factory rims get bent, and cause a vibration, but that should be detected when the tires are spin-balanced. Raise both front wheels off the ground and put jackstands under the frame (for safety), then re-check for any play or slack up/down or side/side in the wheels. Then watch for any slack pr play in the steering linkage while manually turning the tires by hand.
1984 Bronco XLT, 460, C-6 AT, Dana60, Sterling 10.25", 36" GYR RT-II's on H1 rims, S&W Racecars 10-pt cage kit, PRP racing seats, tube doors, Herculiner, custom "shaker" assembly.
1988 Bronco Custom, 302 EFI, C-6 AT, Ford 8.8". parting out
1986 Bronco Custom, 300-I6, NP435 4sp, Ford 8.8", new paint
1988 F-350, 4WD, 460 EFI, C-6Dana 60, Sterling 10.25 (donor)
1978 Bronco Custom, 351M, NP435, Currie Ford 9" w/ spool
1979 F-150 4WD, 351M, C-6, 4.10 gears w/ 35" mud tires
Posted Image
#10 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 06 August 2008 - 08:13 PM
Okay, thank you for the information on the full time 4wd. Is that a decent transfer case? Anyways yes there is a lot of play in the steering gearbox. Guessing there is about 2-3 inches of play before the wheels will start to move, and I know I need to replace it but I just don't have the 300.00$ to replace it yet. When I had the tires balanced they came up good and when it was up in the air I check to see if there was any wheel movement and I didn't notice any. I have to do some work on her this weekend, so I'm going to jack it up and check for any other parts that are moving excessivly. Thank you again for all your help guys.
#11 User is offline   Mike G
  • Bronco Maniac
  • PipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Antique clock repair
Posted 07 August 2008 - 03:09 PM
I went through the same thing on my 92. New shocks and traction arm bushings and L/H bracket. One new ball joint, wheels rotated and balanced, 2 front end alignments. Still between 65 and 74 the front end would vibrate on the road. It was driving me crazy. My tires looked good. So after another 250 mile trip to MO at 65 MPH and troubleshooting by swerving back and forth to load and unload the front end, in neutral coasting, down hill on the brakes off the brakes I finally decided it had to the tires. None of the above changed the vibration. Usually the vibration would change if it was the suspension by putting different loads on it.
Check out the picture of my truck and you can see the tires looked good but they were BAD BAD TIRES.
Man after the new ones were put on what a difference. It rides like a dream. Quite and the steering wheel going straight with the old tires was always left of center. That’s why I got 2 alignments. With the new tires on it tracks straight as an arrow. I've had bad tires before but these were crazy. They were on it when I bought it 7 month ago.
Not saying to go out and buy tires but have somebody have a good look at them. Not Wal-Mart.
Good luck
Mike
  • Attached Image
If it ain't broke, fix it til it is!
92 rust free EB
351Windsor
Traction Lock rear
Warn manual hubs
Heavy duty transmission cooler
12 MPG city
14.6 MPG Highway
Big A$% trailer hitch with electronic brake control
Remote starter and door locks
XM Radio
CB thats been tuned and peaked
Cobra radar detector. Like I need it
Mio C520 GPS
E4OD Front end rebuild and new torque converter
31's
Stock suspension
Stock truck
167k Miles
#12 User is offline   trhaus
  • Duck Tape L'fixer :)
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:building 4x4's and findin the weakest links
Posted 21 February 2009 - 10:54 AM
you could also check the u joint by jacking the front truck up, putting the transfercase in neutral, turn the tires in or out, and try spinning them over to see if they have tight spots where the u-joints bind. that will cause a shimmy, and hey also check the barke rotors for any signs of warping or cracking, because you just never know. as for the gear box mine was fairly loose so i went through my manual and tightened it up.(chilton)
82 bronco 351w auto /w custom soft top.
79 bronco project
67 cougar nightmare
I broke it and it was no accident
#13 User is offline   79RAGTOP
  • Where's My Hammer!?!
  • Pip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 11 March 2009 - 11:09 AM
I THINK TIRES,GEARBOX"STEERING"BOX. I TRY ROTATING TIRES, MAYBE FRONT ONES ARE BAD AS SOMEONE ELSE SAID, ROTATING TIRES IS CHEAP
#14 User is offline   Johnny Reb
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 01 December 2009 - 09:33 PM
Have you checked the bushing (I believe it is called a C -bushing) that goes aroung the axle houseing? When I drove my bronco home-it steered perfect. Then in the spring when I started wokring on it. One C-bushing --WAS MISSING and the other one was beat bad and the sway bar bushing was shot-yet the truck steered perfect---just another oddity-haha,but make a check list of what the guys told you and go down the list and check it all.And as you check each one-check it off. You,d be surprised of what we can miss.
#15 User is offline   Johnny Reb
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 01 December 2009 - 09:36 PM
You might also want to check out the FRONT DRIVE SHAFT. My brother had a 76 fulltime 4 wheel drive and it caused his truck to shimmy. He installed a new one and it quit.
#16 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 04 December 2009 - 04:20 PM
well I have recently replaced every bushing in the front end, but I haven't driven it yet. I took the front driveshaft out to drive home from AZ. to New jersey and I still had the shimmy. Hopefully with all the bushings being replaced in the front will stop it from shaking.
#17 User is offline   muddrivermike
  • Bronco Pimp
  • View gallery
  • Group: Members
  • Gender:Male
Posted 04 December 2009 - 05:28 PM
You know after everybody on here keeps repeating the same things to check over and over again,One thing I picked up was his tires are worn on the outside edges.That shows his toe is wrong.Ive had vehicles have a high speed shimmy from the toe being out.And I have to agree about the tires maybe being bad.I just got done balancing a customers a sequoia and even though it balanced out on the machine at 55-60 he had a shimmy.AND they were new tires,BF goodrich all terrians.Sucks to be him. :D
1978 bronco
351 M
Headers
Dual 3 inch exhaust
C6 Trans
Eledbrock intake
600 holley
DUI distributor
9 inch suspension lift
3 inch body lift
Dana 60 rear
Trac loc in rear
44 frt 8 lug
4.56 gears
40 inch Ground hawgs
8000lb warn winch
Road armor bumper
Kayline soft top
Factory roll bar
http://www.mudspace.com/muddrivermike
#18 User is offline   B1 bronco
  • Bronco Newbie
  • Group: Members
  • Gender:Male
Posted 15 January 2010 - 06:26 PM
Its more than likely your ball joints I had a 79 f150 that did that usually between 40-50 not under or over right in that speed range so it took a tear apart session to find the problem. Quick check jack the front stick a bar in wheel hole if allowed pry up and down better if you have 2 people one just for eyes. That will show ball joint slop if any top ball is usually the first to go if its that easy fix if you have or know someone with press it will save you severaly hundred bucks doing it your self parts might be 100 bucks at most.
Page 1 of 1
Fast Reply
