Jump to content
fiberglass half doors
5 replies to this topic
#1 swampthing
swampthing
    Bronco Commander
  • Members
  • PipPipPipPipPipPipPip
  • 630 posts
  • Gender:Male
  • Interests:if its got wheels i wanna beat on it
  • Favorite Bronco Year?:1978
Posted 12 July 2008 - 07:46 PM
well im not too sure if any companies out there make fiberglass half doors for 78 79 broncos but i plan to make my own...not going to be a complete fiberglass door going to bend up tubing make my own tube door and going to cut an outter skin off of a stock bronco door mold it to where i want it to be halfdoor and make a fiberglass mold out of it....grant it im not into rock crawling or anything but half doors would come in handy for mud seeing as how im always leaning out watching where im going.so hopefully i can get started on this project soon just need to find a set of donor doors...also going to make a set of full tube doors to keep on it
78 ford bronco..getting redone again(does that ever end?)
#2 swampthing
swampthing
    Bronco Commander
  • Members
  • 630 posts
  • Gender:Male
Posted 13 July 2008 - 08:07 PM
any input on this idea?
#3 Justshootme84
    Supreme Commander
  • Moderators
  • PipPipPipPipPipPipPipPip
  • 4213 posts
  • Gender:Male
  • Interests:4wd trucks, hunting, fishing, music
Posted 13 July 2008 - 09:08 PM
I think either fiberglass or sheetmetal will work for your half-door skins, just not sure where you can find a flat piece of glass taht will work. Maybe something from some of the circle track guys? I made a set of tube doors for the 84 Bronco, using the outside spare tire racks, and they work fine. The only real difference I see between the 80-96 and the 78/79 doors is the hinges. On the 78/79 bronco, the upper hinge pin has to be put in from below due to how the fender fits to the cab. I have a little problem with that on my quick-disconnect's for the 78 doors. I normally run without the doors on the trails, but most mud drags make you put the full doors on. I get muddy either way, as I also drive with my head out the side, so I can see where the front tire is going. JSM84
1984 Bronco XLT, 460, C-6 AT, Dana60, Sterling 10.25", 36" GYR RT-II's on H1 rims, S&W Racecars 10-pt cage kit, PRP racing seats, tube doors, Herculiner, custom "shaker" assembly.
1988 Bronco Custom, 302 EFI, C-6 AT, Ford 8.8". parting out
1986 Bronco Custom, 300-I6, NP435 4sp, Ford 8.8", new paint
1988 F-350, 4WD, 460 EFI, C-6Dana 60, Sterling 10.25 (donor)
1978 Bronco Custom, 351M, NP435, Currie Ford 9" w/ spool
1979 F-150 4WD, 351M, C-6, 4.10 gears w/ 35" mud tires
Posted Image
#4 swampthing
swampthing
    Bronco Commander
  • Members
  • 630 posts
  • Gender:Male
Posted 14 July 2008 - 05:19 AM
i was going to just lay layers of fiberglass matting build it up....its not like i absolutely need them just a thought that had popped into my mind..and yeah i am making tube doors out or most liekly 1x1 square tubing.
#5 Justshootme84
    Supreme Commander
  • Moderators
  • 4213 posts
  • Gender:Male
Posted 14 July 2008 - 08:46 PM
Have you ever worked with fiberglass mat and resin? It would be a big job to make some panels without any other support than the tubing.
Posted Image
#6 swampthing
swampthing
    Bronco Commander
  • Members
  • 630 posts
  • Gender:Male
Posted 14 July 2008 - 08:55 PM
yeah i've worked with the mat and resin...i had planned on covering reg sheetmetal door skin that i cut to where i want it and lay it over that...but the more thought i put into it the more i dont want to do it because i will only destroy the doors and it would be a waste of time and money.
Reply to this topic
1 user(s) are reading this topic
