fuel line or carb. problem
ToddJerad
ToddJerad
For the third time I have run out of gas. My 70 bronco has an aux and main gas tank switch on dash as well. The autometer guage is obviously off a quarter of a tank because I died on the road. The prev. owner installed it. When I ran out of gas I tried to switch over to main tank but could not get gas up to carb. even after i put two more gallons in the same tank that went out. Of course I took off air filter and added gas to carb and got the EB to kick. I thought there was a resevoir in the fuel filter or carb so I can switch tanks on empty and start the truck up. I also heard to position the filter higher. This is my first bronco so I am probably experiencing normal problems but does this mean a carb rebuild on my 4 barrel holley is necessary or is this a fuel line/ filter problem or even worse a problem I have to live with everytime I run out of gas? As always thanks in advance for reading.
Crude dude
Phoenix, AZ
A very easy fix that I have found is an electric fuel pump. If there is gas in a tank, it will get it to the carb without cranking the engine. I also have the autometer gauge on my 1970 Bronco and it is also 1/4 tank off. It does take a bit of battery juice to crank long enough to get fuel to the carb. I dont believe that filter placement would help with anything its just out of fuel and if the carburetor is letting the engine run fine then I wouldnt mess with it.
T
ToddJerad
ToddJerad
Thanks, I will replace mechanical one just thought maybe it was a carb problem , as well I know people have there own mounting places, but is lower still better for extracting gas.
"For the third time I have run out of gas."
"...or is this a fuel line/ filter problem or even worse a problem I have to live with everytime I run out of gas?"
Todd..,
The long/short is.., Please don't run out of gas...!!!! [-o<
This is dangerous to you & others as well. [-X
"I thought there was a resevoir in the fuel filter or carb so I can switch tanks on empty and start the truck up."
No
".......so I am probably experiencing normal problems"
YES...normal for anybody who runs ANY veh. out of gas.
If you want real problems..., try this with fuel injection..!!
Just consider 1/4 tank as E-M-P-T-Y ..& gas up/switch tanks long B/4 that...& you'll be a "happy camper" $-)
JLasvegas
its also had on your fuel pump to run on such a low tank, it will burn it up and you will **** up anything sitting on the bottom of your tank
T
ToddJerad
ToddJerad
I know old carb trucks need to add gas before but thought with pumping peddle and trying to crank eventually I could get gas up to the carb. My gauges are way off and thought I had plenty of gas in both tanks. The problem is when I switched to the main tank when puttering it still couldn't get gas to the carb before it ran out and eventually died. Then with 3/4 to a half tank in main line I couldn't get to crank until I poured the gas in the carb by hand. Will the electric fuel pump fix this problem that crude dude suggested and if so would you mount horizontal to the frame similar to if an efi system were installed?
BroncoJoe19
Your problem is that you need to fix your guages, and keep gas in your tank.
Crude dude
Phoenix, AZ
The manual pumps require the engine to be turning over for the fuel to get to the carburetor from the pump. If you run the system out of fuel then you have to basically prime the whole system ( fuel filter, lines and carburetor fuel bowl)with the manual pump and this could eat up a batterys juice and then burn up the starter. You would be better off letting the engine turn over for a while before pumping the gas pedal. The electrical pump will prime the system for you and if you are quick to switch tanks the truck may not even die when running out of fuel. My truck did not have fuel gauges for the first 7-8 years that I drove it and every time I drove it I put fuel in it. It was a pain in the arss to try to get the fuel from the tank to the carburetor due to either a weak battery or a starter that kicked out after cranking a few times. Electrical pump is a great upgrade if you dont mind some buzzing.
Now you've got me curious.... :eek: /emoticons/[email protected] 2x" width="20" height="20" />
Why is it comfortable for you to buy a $100+ elect. pump.....
Rather than manage your fuel & change tanks at a safer level FOR NO $$COST AT ALL...? :unsure:
And you're right ...a clean/tight fuel system will fill the lines..., the fuel pump..., the carb.., & start the eng. with-in a few seconds of cranking...! >
If not.., then something's amiss....like air seepage thru a rubber hose between tank & pump :( /emoticons/[email protected] 2x" width="20" height="20" /> for one...
T
ToddJerad
ToddJerad
I think I am going to go with an electric fuel pump. The reason being that it also comes with the switch I can hide under my dash to prevent theft or at least i will see him 50 yards down the road trying to get it to kick. It seems to be only about 110 dollars to get the pump, hoses, etc. I am also going to rebuild carb as well and hope it runs and starts a little better after. I also tried to crank before pushing gas, switched tanks, starter fluid, etc. but with no fuel in lines I couldn't get it to turn and was afraid battery and starter would lose power soon, so i decided to just fill carb. I figure in a pinch I could hopefully get it started and maybe gain a small amount of performance. Thanks again
Todd..,
With all due respect.... I think you're making a big mistake ("putting a band-aid on..") :-&
Sorry, but after read'n all your posts....best advice is get/find a good mechanic who can help and/or advise you on tasks you choose to do yourself. Then let him inspect. B)
Many folks get in over their heads & put there lives in danger as well as others.
That's what I see here..!
Again..., none of your problems are unique to Broncos of any year. They are basic maintance & up -keep/minor mods that most novice mechanics could handle....on ANY (older) vehicle. At 26.., if you're not at least "novice" it's prob. not going to happen. :ph34r: /emoticons/[email protected] 2x" width="20" height="20" />
Please don't get yourself hurt...@ that's no fun at all............. :((
T
ToddJerad
ToddJerad
I have experience with bikes and have people helping or else I could never have done half the things. This forum has also led me to many answers that mechanics and so called experts had 0 input on. I am not sure how my life is put in danger; most things on a car can be fixed, rebuilt, and replaced with some knowhow and with help it ain't too difficult. Driving on streets in an industrial area with no traffic to test all problems and wasting little gas by not filling up completely (my stupid mistake when i took longest drive to muffler shop) is more mindless than dangerous. It is easy to replace fuel lines, add EFI, full tune up, complete rebuild, disc brakes, power steering, show paint, etc. when money is no object. If I wanted a $15,000 bronco or maybe $30,000 i can find them all day long for sale, but buying someones trash for nothing, turning it into a car you always loved by doing the grunt work yourself, and getting the EB communities advice to fix the immediate problems are much more feasible on my budget.
BroncoJoe19
ToddJerad,
You are not going to get any additional performance from adding an electric pump. Do you plan to add a high pressure electric pump, or a low pressure one?
You said that your actions were "mindless" not BullyBob, though I suspect he would like to. You also said that you are working on a budget. For five dollars, you can buy a toggle switch, and put it in line with the 12 volt line that goes to the BAT side of the coil. Flip that switch, and the car/truck will never start. WHY spend $100 American on a pump that you do not need, and justify its expense because it comes with a switch? You'll also have to buy, and install the relay switches, etc!
In reality, your problem is simply you do not know when you are dangerously low on gas!
I was thinking about your comments earlier today, and likened them to this...
If a person's roof is leaking, the solution is NOT go out and buy a new mop!
You have bad guages, and run out of gas. Instead of fixing the problem, you want to put in an electric pump so that it is easier to start after you run out of gas! Do you plan on running out of gas on a regular basis?
Doesn't it make sense to you to fix the guages problem first?
You have me baffled.
Yes..., what Joe said..!
Mr. Jerad...,
My friend, have you ever taken an autoshop class..? If not.., it would be a great benefit to you....for half a dozen reasons.
By all means.., use all the EB boards for advice...but understand, without laying an eyeball on the problem/s ... this is really a guessing game. Especially having to rely on the discriptions that pop up.
"wasting little gas by not filling up completely"
Baffled here..??
"I am not sure how my life is put in danger"
You do understand elect. fuel pumps don't shut off in a crash...??
P/S & P/B quit when eng. stalls..?
Not sure how others think..., BUT, when I answer a question/problem here...I do so as though I'm talking to 5-10-maybe 100 other folks with a simular problem. So don't take what I say personal.
My #1 goal is safety...I discourage & talk down tasks that are otherwise..!
Having said all that..., I'll not "chime-in" on your posts in the future.., for obvious reasons..., but I wish you only the best of luck & yrs. of fun with your rig.
STLKIKN
Calgary Alberta
My opinions...
As stated, you should look into fixing the fuel gauge first and foremost.
IF you install an electric pump and continue to run it out of fuel you risk damaging the electric pump as well (they use the flowing fuel to lubricate and cool the pump)
You can install a toggle switch into either your starter wire or your coil wire as a quick cheap anti-theft device.
You can also use your fuel tank switch as an anti-theft device (how many people know that the gauge switch and the tank switch are separate thing in the EBs?)
If your Bronco has a manual transmission, at the first sign of coughing or sputter, you should switch the tank, if I switch any of my EBs at that time, I can still coast through the change over. (Meaning that it will cough and sputter until there is good flow from the second tank) The only time I have had an issue with changing tanks was the first time my other half ran our old 77 (auto tranny) out of fuel and I had to go start it for her for the same reason that you have had issues.
Yes, if you run it completely dry before switching, you have to allow time for the pump to try and draw fuel through a dry system, meaning filling the lines, priming a dry pump, filling the filter, and then the fuel bowl or bowls on your 4 bbl... quite a lot of cranking if I do say so myself...
Good luck with your decisions here, but remember just by changing the way you approach the problem, you may save yourself some time, effort and money.
T
ToddJerad
ToddJerad
Didn't fill completely bc car is sitting in warehouse and had a couple of 2 gallon tanks I ran to gas station with. Guage said quarter tank before (now i know thats wrong). I will stray away from electric fuel pump and maybe change out lines soon (since its probably been 38 years anyways) and see if this helps bc maybe leakage is the problem even though I checked for cracks and bad connections, maybe replacing them will be more beneficial as what Bully said. I also think a lot of people add electric fuel pumps to their lines that use holleys or other carbs to replace the manual ones, are they wasting time and money? I know there are benefits and I do know the truck will have no shut off in a terrible accident if I can't hit switch. The truth is people will tell you all day long to put this in, take that out, but unless you get advice from experts like you Bully on broncos (im sure you could build them ground up with a blindfold) and some help from those who went to school, it really helps amateur mechanics . And in regards to STLKIKN, I still couldn't get fuel up after lots of cranking, pumping, until i just poured fuel into carb so i knew there must be some problem hence the asking for advice. I also tried to switch when puttering and still running with no avail. By now I have replaced and upgraded most parts under hood so I don't think i am throwing gas on fire just want an updated version of a 40 year truck and trying to take it step by step. Gauge will be tested even though have feeling it is senders. All advice is greatly appreciated and I only tackle jobs doable by everyday people who want to know how to keep their car serviced and running properly since it is a long term investment (probably a losing one). And why fuel isn't getting up the lines seems like a decent topic others may need to know as well. Thanks again I will try to keep it to EB specific questions.
Crude dude
Phoenix, AZ
ToddJerad , I want to apologize for giving you advice that could have killed you and possibly the rest of the neighborhood. The commanders will take over from here. Good luck
STLKIKN
Calgary Alberta
Crude dude, I don't think anybody meant it that way....
But, if you are running an electric fuel pump a great safety feature is an oil pressure cut off switch.
Wire your relay trigger wire through an oil pressure sensor that switches on/ off, you can add a "t" fitting to the end of the factory pressure sender extension and install the switch there.
It may take a second or two for the oil pressure to build and trigger the switch when cranking/starting, but in the case of an accident where the switch no longer senses oil pressure, the fuel pump will shut off hopefully preventing any further damage.
BroncoJoe19
Crude dude, I don't think anybody meant it that way....But, if you are running an electric fuel pump a great safety feature is an oil pressure cut off switch.
Crude dude, I never considered that you didn't install your's properly, but if you didn't then you should certainly include some kind of an automatic cut-off safety switch. The newer broncos with electric fuel pumps use an inertial cut off safety switch. They are inexpensive, and I imagine easy to install.
Now just to be clear... I am not a professional mechanic, nor an engineer. You and anyone who reads this and any thread I participate in is on your/his own. Whenever one makes a modification, or deviation from factory original, that person assumes the risk and any liabilities associated with that deviation and any safety issues.
The titles of village idiot, or Supreme Commander have nothing to do with the amount of knowledge or experience that a member has. It is simply a reflection of the number of posts one has made in this forum. One can post LOL to a thousand jokes in the tavern section, and attain the title of Supreme Commander.
joe
msgsnprtom
