Ford Bronco Zone Early Bronco Classic FullSize Broncos: Need Help with cooling - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
  • (2 Pages)
  • 1
  • 2
#1 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 17 June 2008 - 02:08 PM
Hello everyone, I need some serious help. I have a 78 bronco with a 351M, new 2 row alumminum radiator, new hoses, new OEM replacement water pump, stant 180 degree T-stat, OEM clutch fan setup, and in the Phoenix, Arizona heat I have an over heating problem. Does anyone have any suggestions to what I can do to get it to stay cool. I would appreciate any help.
P.S. I put the T-stat in it the other day and I believe I have gotten all of the air pockets out of it. I'm going to try to rebleed it but I'm just wondering if anyone has any suggestions. Thanks
Mike
1978 Ford Bronco, 351M, Edelbrock cam,600cfm carb, performer 400 intake, headman headers, side pipes. 4 inch. suspension lift.. All wheel drive.
#2 User is offline   79rag
  • Duck Tape L'fixer :)
  • PipPip
  • Group: Members
  • Gender:Male
Posted 18 June 2008 - 01:58 PM
well i put a 4 core copper radiator and duel electric fans in mine works great
dont have to fans on while on the highway and you get alittle more hp
#3 User is offline   BroncoJoe19
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 18 June 2008 - 02:28 PM
Mike
Mike,
On an emergency basis, one can get a little extra cooling buy turning on the heat.
I'm not suggesting that as a long term solution by any means.
But it may help you get home when you need to.
joe
BroncoJoe19... I am not a professional mechanic, nor an engineer.
One should always obtain professional advice before attempting a repair or modification.
1990 Tan on Black Eddie Bauer - resides in North Jersey
302 with 33's on 15s E4OD Speedometer corrected trans
Auto hubs with manual transfer case snorkel
#4 User is offline   Leadsled
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 18 June 2008 - 07:50 PM
View PostBroncoJoe19, on Jun 18 2008, 03:28 PM, said:
Mike,
joe
Test your new t-stat by putting it in water on a stove along with a thermometer. when the spring collapses see what temp you have. i do that to all of my new t-stats and found that you run across quite a few bad ones.
#5 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 18 June 2008 - 08:29 PM
Thats the way I've been driving it around here, with the heat on but the 100+ degree weather in AZ. plus the heat on.. just bad news right there.. What size electric fans are you running? I actually had the overheating problem without he thermostat, so I thought if I put one in it would cool the anti-freeze off a little bit because of it sitting in the radiator a little longer but I was wrong..
#6 User is offline   Crude dude
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 18 June 2008 - 09:37 PM
Are you going off of a gauge or is the radiator actually burping coolant? If it is spewing out of the radiator then maybe try a new radiator cap?? Pressure spring may be tired in the cap. I am also in Phoenix if you want to try using my cap tester. Not thats its very expensive to buy a new cap but it will tell you if it is possibly the problem. I am also going to part out my 78 XLT Ranger so if you need some parts....
1970 Bronco , 1978 Bronco Ranger XLT, 2007 Dodge Cummins 4x4, 2003 4Runner V8 Limited
#7 User is offline   BroncoJoe19
  • Supreme Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 19 June 2008 - 03:29 AM
Good questions!
Can the clutches in the fan go bad?
IF so... could bad clutches allow the fan to turn too slowly?
I understand that they are to allow the fan to turn faster than the engine (when at highway speeds) so I am thinking that they should allow slippage in only ONE direction, but I don't know.
#8 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 19 June 2008 - 01:47 PM
The radiator cap is brand new. It doesn't leak any anti-freeze unless I take the cap off and start it and let it run that way. I found out today driving to school that if I go between 65-70mph. the temp gauge will read between 210 and a little higher, but if I go between 50-55mph it will read at 210 which I don't understand. When I was bleeding it, it would actually blow some good bubbles, but they all seem to go away. and parts I'll always need parts. I'm particularly in need of a gear box, and round headlight bezels, but if that is an xlt that comes with square headlights right??
I'm not sure about the clutch fan, I was always told if you can spin the fan without the clutch spinning it was okay, and if you couldn't spin the fan without the clutch it was bad and to replace it. I'm not sure on that either. I'm going to do a little searching for it. Just to make sure, if you have a 180 T-stat it should run somewhere around there correct? And I've looked, but not hard. Does anyone know the temp these 351M engines at?
#9 User is offline   79rag
  • PipPip
  • Group: Members
  • Gender:Male
Posted 19 June 2008 - 02:48 PM
im runnin the fans out of taurus and do you have a fan shroud if not you will run hot sitting in traffic
#10 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 19 June 2008 - 02:54 PM
I do have a fan shroud on the truck
#11 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 19 June 2008 - 02:56 PM
Does it make any difference of the fact that it is bored .30 over?
#12 User is offline   Crude dude
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 19 June 2008 - 05:18 PM
The fan clutch actually free wheels all the time. When the engine is running warm the fan clutch will firm up and free wheel less actually becoming closer to a direct drive. A thermostatic fan clutch is the only way to go in hot weather. They are expensive but they have solved my over heating problems more than once. A dead giveaway that your fan clutch is not working is when the engine is at operating temperature, have someone shut off the engine and the fan should stop spinning within approximately 1-2 turns. If it spins freely then your clutch is not cooling your radiator. At freeway speeds the fan clutch should be a little looser so that there is not so much drag on the motor. Have you ever heard those people driving down the road with the a/c on and it sounds like the fan is pulling them down the road? I have read that the 351/400 engines usually run hot but mine does not. I upgraded my 351M to have a sanden air compressor so the a/c is more efficient than the york compressor. Are you running a/c?
This post has been edited by Crude dude: 19 June 2008 - 05:24 PM
#13 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 19 June 2008 - 06:38 PM
Where would I go to find a thermostatic fan clutch, because I'm willing to do anything to get this thing cool. I do have A/C and would like to use it, but can't.... It is the factory unit and I do need to replace it soon because its noisy, and I can't remove it from the engine, for some reason when I take out the one bolt on top of the compressor freon starts coming out. So eventually I will need to get another one of those, but cooling is the first thing I need to take care of, then the steering... The steering has excessive play in it and it all leads back to the gearbox..
#14 User is offline   Ranger429
  • It's Only Money, Right?
  • PipPipPip
  • Group: Members
  • Gender:Male
Posted 20 June 2008 - 04:59 AM
Any parts store will have one. A thermostatic fan clutch has a coil like a choke thermostat on the front of it. When the fan clutch coil starts to warm up it starts to release the fluid inside the fan clutch which makes the fan spin freely as it warms. The warmer it gets the more fluid it releases the easier the clutch spins.
Posted Image
79 Bronco Ranger XLT Mildly built 400, 4" lift 35" Cepeks, from CA with full restoration
79 F250 Ranger XLT '70 429 Thunderjet, balanced and blueprinted, mild cam, DOVE head's with roller rockers, stealth intake, holley 770, Dana 60 F+R with 4.10's, Custom 6" lift and 36" Fun Country radials
79 F-250 Crewcab 4x4 Under restoration
Did FORD still make a truck after 79?
http://7879blueovalbronco.com/
#15 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 20 June 2008 - 01:46 PM
Thanks for the help, when I get back from New Jersey I will go pick one up and hope and prey it helps with my cooling problem..
#16 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 21 July 2008 - 12:18 AM
well I got back from jersey and bought a clutch. The guy at the 4x4 place in jersey said to try an additive called 40below its made by prolong, and between the 2 it seems to have cooled off about 15 degrees or so, and runs great at night and during the cooler days of Phoenix, but on the nice and hot days it starts to climb again. So I'm almost back to square one again, but made a little progress.. if anyone has anymore suggestions let me know please.. thanks
Mike
#17 User is offline   BroncoJoe19
  • Supreme Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 21 July 2008 - 04:40 AM
Mike,
I did a quick search for auxillary cooler at JCWhitney
http://www.jcwhitney...uxillary+cooler
I'm not suggestiong that is the way to go, just an option.
#18 User is offline   trhaus
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:building 4x4's and findin the weakest links
Posted 21 February 2009 - 11:11 AM
i would install a larger rad. every 351 / 400 i have had runs hot.
82 bronco 351w auto /w custom soft top.
79 bronco project
67 cougar nightmare
I broke it and it was no accident
#19 User is offline   Fritz180
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 21 February 2009 - 01:01 PM
what is considered hot? I moved back to New Jersey so it runs at like 190 now but its also the winter and about 30 degrees outside.
#20 User is offline   Yoder
  • PipPip
  • View blog
  • Group: Members
Posted 24 February 2009 - 07:05 AM
i have a 79 bronco with a 351m and i run at about 200 whether its 70 or 30 degrees if that helps any at all but i took it mudding last weekend in about 55 or 60 degree weather and it was getin hot but when it wasnt hot it ran at 200 degrees.
  • (2 Pages)
  • 1
  • 2
Fast Reply
