Ford Bronco Zone Early Bronco Classic FullSize Broncos: Lift Kits - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Lift Kits how big a lift
#1 User is offline   rooster
  • Bronco Newbie
  • Group: Members
Post icon  Posted 28 July 2004 - 04:45 AM
[-o< how big a lift can you go on a 77 before you have to cut axles to compensate for the angle?
#2 User is offline   Broncoholics
  • Broncoholics
  • PipPipPipPipPipPipPipPip
  • Group: Moderators
  • Interests:4-Wheeling!
Posted 28 July 2004 - 02:03 PM
From what I see the 5.5" should be the max height. Even if the front axle is rotated and pointing upwards inline with the driveline you will have a bind where it connects to the t-case. Otherwise you will need to talk to www.highangledriveline.com and spend lots of cash on a special driveline. Dissconnect your front driveline off the Dana44 end and see how far it drops, then try to turn it. You will find you can't turn it when its all the way down because its in a bind. Then lift it a few inches and you will start to be able to turn it. Thats the location of the lowest point unless you lower the t-case. Lowering the t-case is the best thing you can do to save u-joints and keep the center of gravity lower. Problem is you can get high centered easier but with the short wheel base and power of a Bronco who cares. You want it in a happy medium location for suspension articulation, this is why I run a 3.5" lift and added a 2" body lift to gain clearance for the 38's! Seems to work for me...
Attached thumbnail(s)
  • Attached Image
302, NP435, NP205, HPD60, D70, 5:13 Gears, Detroits, 3/8" Diff Covers, 35 Spline Yukon Chromoly Shafts, Ator Drive Flanges, Cage 5.5" lift, Trail Ready Bead Locks, 38" SSR's, 1350 Drivelines, Ram Assist Steering, Stone Crusher Steering/ trac bar, 98" wheel base.
Page 1 of 1
Fast Reply
