Well I have installed the new MSD box and coil. Did the test light thing. I have power coming from the ignition but nothing to the coil? Anyone know why? I bought a used MSD box and I had the same problem. I didn't have any fire to the plugs. So, I bought a new box and voila, the same thing. NO F___ING POWER TO THE COIL!! Yes the battery is low, but I still had power to do the test light. Now when I turn the key, NOTHING!!!!!!! I did hear the solenoid kick in. Other than that, nothing. Can't just be the battery. I would have had some turn on the engine. I also would have had the test light come on. I'm about to take this damn thing to a mechanic and spend the but loads of money to get it running.
Socronaut,
What test light thing did you do?
When you say that you have power coming from the ignition, do you mean the ignition switch?
Where did you test for power... i.e. where do you have power going, if not to the coil?
OK, I think I got the picture now.
You turn the key, and you hear the starter relay and or the solinoid click. So you know that the ignition switch is working, and you have power at least to the starter relay, perhaps the solinoid.
When you turn the key on, and you put a test light to the bat side of the coil, does the light go on? I'm guessing that it does not.
(If that's the case, then you have a break in the wire that is going from the ignition switch to the bat side of the coil. I'm not sure if there is a fuse between the ignition switch and the coil, so just for the sake of it, take a look at your fuses and replace any that are blown)
You can temporarily (for testing purposes) run a wire from the battery to the bat side of the coil. Now turn her over and see if she starts. IF not, check for spark. If none, pull the cap and have someone else crank the engine and see if the rotor is turning inside the distributor.
DId you change the pick up coil that is INSIDE the distributor? In the diagram linked to above, it is called the "stator assembly".
