If I have to pull it again..........anyone in Northeast GA got a decent 302 they wanna get rid of cheap??
Thanks.
Posted 26 March 2008 - 12:15 PM
Posted 26 March 2008 - 01:39 PM
Posted 26 March 2008 - 03:32 PM
Posted 26 March 2008 - 11:00 PM
Posted 31 March 2008 - 06:41 PM
Posted 31 March 2008 - 07:40 PM
Yahoo!!! I love it when a plan comes togetherTracked down the leak. Replaced the dipstick tube and that didn't help, so i start tearing the drivers side of motor apart. I remove the exhaust manifold to make sure I don't have any visible cracks and feel up under the valve cover and see that part of the gasket slipped inside the cover. I pull the valve cover and the gasket above the #6 and 7 cylinder is oiled up and not sealing. I slip it into place and run a bead of RTV and bolt it all back together. VIOLA! No more oil leak.
Now I have to figure out why after it warms up my oil pressure wants to drop but motor doesn't make any odd noise. (I saw another thread about it) and hoping that there isn't anything to major with the tranny/rear-end. Seems to not drop into passing gear when climbing a hill, or downshifts too soon. And seems alil herky-jerky when going down the road.
Thanks for the leads.
Posted 31 March 2008 - 08:19 PM
Hmmm my Haynes manual says that the E4OD supplemented the AOD in 1988.So if I have just the AOD....i guess pull the codes and see whats going on. I see no OD switch anywhere.
Posted 31 March 2008 - 08:24 PM
I just went out to look at the sticker on my door panel, and found that the Trans Type was "E"Hmmm my Haynes manual says that the E4OD supplemented the AOD in 1988.
My switch is to the right of the steering wheel, on the lower dash panel.
Definitely pull codes. You want her running as well as possible.
