Ford Bronco Zone Early Bronco Classic FullSize Broncos: Gears and Axle code - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
  • (2 Pages)
  • 1
  • 2
Gears and Axle code
#1 User is offline   89eddie89
  • Bronco Maniac
  • PipPipPipPipPip
  • Group: Members
  • Gender:Male
Posted 19 February 2008 - 05:31 PM
Ok I found the axle tag, and the code # is S807D L55 8 8 9D12.
So by this # what are my gears and axles??
'89 xlt eddie bauer
4" superlift ttb
35" pro comp mudz
flomaster 40 side exhaust
more to come..
#2 User is offline   Justshootme84
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • Group: Moderators
  • Gender:Male
  • Interests:4wd trucks, hunting, fishing, music
Posted 19 February 2008 - 07:52 PM
The top line "S807D" is termed the "Bill of Material" number. That's used for when you order parts, like axles or bearings, so they match your specific axle. Certain BOM's can also be used to ID the axle, such as the Ford 8.8". The bottom line is what you need to tell the gear ratio and axle type. It should read something like "3L55 8 8 9D12". The first number series in the tag is the gear ratio, and whether the axle has factory limited slip. In some cases, the first number of this series is covered up by the bolt holding the tag to the cover. That's why your's reads "L55 8 8 xxx". This is indeed the 3.55:1 gear ratio with the factory Trac-Lok limited slip. The next series is the axle type, that being the Ford 8.8" ring gear. The last series of numbers is the build date, which is Ford's code for the month and year the axle was built. JSM84
1984 Bronco XLT, 460, C-6 AT, Dana60, Sterling 10.25", 36" GYR RT-II's on H1 rims, S&W Racecars 10-pt cage kit, PRP racing seats, tube doors, Herculiner, custom "shaker" assembly.
1988 Bronco Custom, 302 EFI, C-6 AT, Ford 8.8". parting out
1986 Bronco Custom, 300-I6, NP435 4sp, Ford 8.8", new paint
1988 F-350, 4WD, 460 EFI, C-6Dana 60, Sterling 10.25 (donor)
1978 Bronco Custom, 351M, NP435, Currie Ford 9" w/ spool
1979 F-150 4WD, 351M, C-6, 4.10 gears w/ 35" mud tires
Posted Image
#3 User is offline   89eddie89
  • Bronco Maniac
  • PipPipPipPipPip
  • Group: Members
  • Gender:Male
Posted 20 February 2008 - 05:23 PM
Thanks JSM.
Now I know my gears! Haha
:D
'89 xlt eddie bauer
4" superlift ttb
35" pro comp mudz
more to come..
#4 User is offline   jsomedaysoon
  • Bronco Pimp
  • View gallery
  • Group: Members
  • Gender:Male
Posted 25 March 2008 - 05:25 PM
my door jamb sticker says that i have the 8.8 rear end with a factory limited slip. i did the trick where you lift the back wheels off the ground and the wheels spun oposite. if i remember correctly from an earlier post this means that i do NOT have a limited slip. so i tried to read the axle tag but it was rusted and covered with crap. i did the trick where you scrible a pencil on a piece of paper over it and this is what i got. tell me if it makes any sense. i think i got.... 8.8 or 8.6 (it is an 86 truck) 3 f 15 on a seperate line i see what apears to be a 388 if these numbers dont make any sense i'll try to clean it off better and read it again.
1986 efi 302 out of a 91 mustang, 33x12.50 mickey thompsons, headers, everything else stock as far as i know.
1984, carb 302, all factory so far exept the 33's and the manual locking Warn hubs.
#5 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 25 March 2008 - 07:12 PM
Try cleaning it again, you want to rad the bottom line of numbers starting from the bolt. You can also compare your gear ratio on the front axle ID tag. If your axle code is "H9", you should have 3.55 gears and factory limited slip in the Ford 8.8" rear axle. The front Dana44 TTB axle should be open with 3.54: 1 gear ratio. At least that's what your Bronco came with from the factory.
Posted Image
#6 User is offline   jsomedaysoon
  • Bronco Pimp
  • View gallery
  • Group: Members
  • Gender:Male
Posted 26 March 2008 - 03:28 PM
okay i'll try this weekend. i do have the h9 axle code on the door jamb but i think i mentioned that the rear wheels spun oposite when i lifted the rear end off the ground. i'm just curious if i do have a limited slip or not. is it posible that the factory limited slip has not been taken care of and failed. would that cause the wheels to spin oposite? i'm not sure of the complete history of the truck but i do know tha not much on the truck is factory.
#7 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 26 March 2008 - 10:48 PM
The surefire way to tell what you have is to remove the rear cover, and check if the gears and L/S have been replaced or not. The gear ratio should also be stamped into the ring gear, but I wasn't able to find it on my 88 Bronco when I gutted the 8.8" axle. If you have high mileage on the Bronco, it's certainly possible that the trac-lok is worn out and not working.
Posted Image
#8 User is offline   markmn123
  • It's Only Money, Right?
  • PipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 02 July 2008 - 06:43 PM
what kind of power numbers can the 8.8 hold up to? or if it was rebuilt?
yea im a noob...SO WHAT!!!
It had such a good reputation until O.J. got one
#9 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 07 July 2008 - 07:08 PM
You might ask that in a new post, to keep this one related only to the tag ID, JSM84
Posted Image
#10 User is offline   BLADE262US
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
  • Interests:Ford there is nothing else =)
Posted 08 July 2008 - 05:17 AM
I agree with JSM on the worn limited slip . The clutchs wear very fast in tohose things and they will act just like an open diff doing the spin the wheel test . :D
#11 User is offline   markmn123
  • PipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 08 July 2008 - 03:18 PM
sorry! :blush:
#12 User is offline   Bronco_Willis
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 02 September 2008 - 08:47 PM
Ok so here I am joining this thread. How can I tell what kind of front I have, if there is nothing readable on the door jamb? There is a tag on it but it read like this : 4 09 "upside down triangle" E7TA A. Thats the top line. Bottom line is this: "upside down triangle" 610267-6. Are these numbers irrelevant in figuring out my front end?
#13 User is offline   bigtimmer
  • Bronco Newbie
  • Group: Members
Posted 01 October 2008 - 01:59 AM
i have heard of welding the spidergears in the rear end together to make it a full positive traction
#14 User is offline   92bronco_in_progress
  • Yeah its a 92 bronco
  • Group: Members
  • Gender:Male
  • Interests:heavy metal, wheeling, PS3
Posted 17 November 2008 - 06:35 PM
most broncos have a dana 44 up front.....axle ratio is the same as the rear.....so if you have 3.55 out back you have 3.55 up front, they have to match
1992 Ford Bronco XLT
5.8L Automatic
3.55 Traction lock
Flowmaster muffler
Stock hieght, FOR NOW
Daily Driver : 2003 Dodge Ram 2500 5.7 Hemi, Gibson swept side exhaust K&N drop in Air Filter
#15 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 23 February 2009 - 06:53 PM
Some have asked for pics to help ID the axle model. Here is the Ford 9" from my 84 Bronco. The rear cover is welded on, and the whole differential or 'chunk' comes out thru the front side or same side that the driveshaft goes in:
Posted Image
The metal ID tag is attached to one of the bolts:
Posted Image
Here is the Ford 8.8" from my 88 Bronco. The rear cover is bolted on, and the ring gear+carrier comes out the back side/ opposite of the driveshaft. The ID tag is bolted on the back cover:
Posted Image
Posted Image
#16 User is offline   jka7904
  • Bronco Newbie
  • Group: Members
Post icon  Posted 19 March 2009 - 05:03 PM
Ok....I am trying to figure out the code that should be on my rear end. I'm thinking it should be S807D 3L55 8 8 ....but the tag is no longer on my rear end. Does this sound like a common code? Also, in the driver side door jamb, it has an H9. I know this stands for the limited slip option, which I know that my rear end is a limited slip with 3.55 gears and 8.8 so....can anyone help?
#17 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 25 March 2009 - 05:56 PM
You are correct. Might look on the front TTB axle pumpkin for the ID tag, should have a 3.54:1 gear ratio to match the 3.55:1 rear axle. JSM84
Posted Image
#18 User is offline   randyb
  • Bronco Newbie
  • Group: Members
Posted 18 June 2009 - 08:05 AM
ok Here is my axle code S838J (FIRST LINE) 3 55 88 5A27(SECOND LINE) NOW I AM ASSUMNG from what I have read that this is a 3.55:1 ratio 8.8 rear end, now there was no L in the number so does this mean there is no limited slip? also how do I identify if it is a DANA 44 ,70 or what?any help would be appreciated> thanks in advance
#19 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 18 June 2009 - 10:24 AM
You are correct, that is the tag numbers for a Ford 8.8" rear axle, with 3.55 gears and no limited slip or what's called an "open" differential.
Posted Image
#20 User is offline   Steve83
  • Bronco Guru
  • Group: Members
  • Gender:Male
  • Interests:DVDs, MP3s, Broncos, Crown Vics, radio controlled models, home theater, home improvement
Posted 18 June 2009 - 12:17 PM
Posted Image . Posted Image . Posted Image
http://www2.dana.com...rms/demenu.aspx
  • (2 Pages)
  • 1
  • 2
Fast Reply
