Ford Bronco Zone Early Bronco Classic FullSize Broncos: 88' Transmission crossmember - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
88' Transmission crossmember Any mods or advise ?
#1 User is offline   Broncobill78
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • Group: Members
  • Interests:78/79 Broncos<br />4 wheeling in the mud w/the family<br />thinking about a small boat for family use<br />Teaching my boys how to fix, repair &amp; rebuild &amp; being proud that my daughter is just as interested.
Posted 18 February 2008 - 10:22 PM
Just getting ready to put the tranny crossmember back into my 88'. It's been out long enuf that I had kinda let myself forget what a freaking hassle it was to remove the damn thing in the first place. I don't suppose anyone's come up with any mods or good suggestions for putting this damn thing back in that don't include the words "it's a bitch" ? Taking this thing out reminded me why I started doing Frame-off's. I think the Better Idea guys were out smoking crack when this thing was designed. If anyone has something other than a brure-force approach to putting it back in I'd REALLY like to hear about it because in about 12hrs I'm grabbing a 3lb maul & going to town on it. Any legimate input will be GREATLY appreciated. My neighbors are *tired* of seeing this thing up on jackstands and I have to convince the neighborhood association that it really *isn't* a $hitty lawn ornament so I HAVE to get it up & running again but my patience with this thing is truely limited. Has NOBORY come up with a batter arrangement for the crossmember ? I am NOT removing the entire damn exhaust just for those two stupid bolts, it's insane & I refuse to do it. I'll weld the damn thing before I do that.
Dave
People who say it can't be done should not interrupt the person doing it.
84 Mustang GT (Great car to lose your license with, I recommend it for those trying to do so)
74 Ranchero (429, c6, Currie enterprises 9" w/Mickey Thompson cheater slicks, 1970 Torino shaker hood scoop)
82 Bronco (Canadian truck, kilometer speedo, dual batteries, hi-output heater, dual factory block heaters/etc)
78 Bronco (400, 33" Fun Countries, fastback softtop)
79 Bronco (460, 36" Ground Hawgs, frame-off rebuild)
84 Bronco (bone-stock beater)
73 Bronco (I only had it 2 wks before flipping & crushing it.)
76 F-350 (390, 40" Super Swampers, ugly ugly ugly fire-engine green/yellow cab w/faded purple bed)
78 Bronco (460, 38.5" Ground Hawgs, Dana 60's, boxed frame, frame-off rebuild)
86 Bronco (only truck I've ever had fall thru the ice & just plain disappear. no end of hassles from the ins. co.)
91 Bronco (25th anniversary edition, red w/grey leather everything interior, 31x11.5's)
88 Bronco (33x12.5's)
79 Bronco (Current project, 4" lift w/weenie little pizza cutters)
Looking for 78/79 parts, please let me know if you have one you're parting out.
#2 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
  • Interests:4wd trucks, hunting, fishing, music
Posted 19 February 2008 - 12:48 PM
Not sure what the problem is? When I put the C6 from the 88 F-350 into the 84 Bronco, I tried using the F-350 crossmember. No problem bolting it in, just that it made the C6 hit the floor due to the one-pirce tranny mount. I swapped back to the Bronco C6 crossmember and the two-piece bushing style mounts. No problem bolting the crossmember back in. Onlt thing I can say is to unbolt the end pieces, so it's easier to fit together once under the Bronco. I even re-used the factory bolts and self-locking nuts. Four per side. I did clean and paint the crossmember, as well as clean and bedliner the frame. So I don't have any dirt or debris to get in the way. And the exhaust is the last thing that's going back on the rig, because I may swap t-cases from the NP208 to a B-W 13-56 or an NP205, JSM84
1984 Bronco XLT, 460, C-6 AT, Dana60, Sterling 10.25", 36" GYR RT-II's on H1 rims, S&W Racecars 10-pt cage kit, PRP racing seats, tube doors, Herculiner, custom "shaker" assembly.
1988 Bronco Custom, 302 EFI, C-6 AT, Ford 8.8". parting out
1986 Bronco Custom, 300-I6, NP435 4sp, Ford 8.8", new paint
1988 F-350, 4WD, 460 EFI, C-6Dana 60, Sterling 10.25 (donor)
1978 Bronco Custom, 351M, NP435, Currie Ford 9" w/ spool
1979 F-150 4WD, 351M, C-6, 4.10 gears w/ 35" mud tires
Posted Image
#3 User is offline   Broncobill78
  • Supreme Commander
  • Group: Members
Posted 19 February 2008 - 01:44 PM
Yup, I removed those wing-thingies when I took it out. Problem was that the exhaust on the pass side was right down on top of the bolts & made it a bitch to remove (had to cut the bolts to remove that side). Removing the exhaust would have helped but after looking @ the studs on the manifolds I was pretty sure they'd snap if I tried & drilling & tapping a new set of threads into a pair of 20yr old manifolds is not my idea of a fun way to burn thru a weekend. Got everything in ok this afternoon. Took the alternate road and unbolted the motor mounts then jacked the whole engine/tranny combo up until I had enuf clearance to slide the pieces to the crossmember back into place. Just taking a break now. Still need to get some silicone to reattach the transfer case & some ATF. Know anything about changes in AOD pans ? Strangely the AOD that was in there originally had a square, flat-bottomed pan w/the word "Metric" stamped into in in 4" letters. The AOD I just put in has no lettering stamped into it and it has a rectangular hump projecting out from the bottom of the pan. Haven't had a chance to ck any sites yet for info, just thought it was odd. That & the fact that the AOD I just put in had a metal data tag on it.
This post has been edited by Broncobill78: 19 February 2008 - 01:46 PM
Dave
#4 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
Posted 19 February 2008 - 01:47 PM
I believe the AOD pan with the hump is from a 4wheel drive AOD
Posted Image
Page 1 of 1
Fast Reply
