Ford Bronco Zone Early Bronco Classic FullSize Broncos: Brake Code - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
Brake Code I'm always learning it seems
#1 User is offline   michibronc
  • Bronco Maniac
  • PipPipPipPipPip
  • Group: Members
  • Gender:Male
  • Interests:Hunting, fishing, gardening, breaking my trucks and trying to fix them.......
Posted 17 February 2008 - 07:46 PM
Hi All,
My ABS light keeps coming on - almost always when my ABS kicks in when I stop too fast on snow. It also shuts off after a few starts. I took it to a shop, they pulled the code for me. 63 - (Pump motor triggered but did not run). The brakes seem to work fine but I do have more pedal travel lately. I also had to add some fluid recently (about half to three quarters of a bottle). I've looked and so did the shop for leaks etc but could find no culprit. The pads seem to be good, so I can't figure out why I have extra pedal travel and had to add fluid. I'm wondering if the code, pedal travel, and low fluid are related. Does anyone have experience with similar problems?
'96 Bronco XL
E4OD
351W
31x10.5's
Manual Transfer Case
Rancho RS5000 Shocks and stabilizer
Warn Premium Locking Hubs
#2 User is offline   Broncobill78
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • Group: Members
  • Interests:78/79 Broncos<br />4 wheeling in the mud w/the family<br />thinking about a small boat for family use<br />Teaching my boys how to fix, repair &amp; rebuild &amp; being proud that my daughter is just as interested.
Posted 18 February 2008 - 06:47 AM
Might be a problem with the vacuum booster. Sometimes when the booster fails the internal diaphram tears and fluid from the MC gets in there. If you're losing fluid and the rest of the systems is tight & dry then chances are good that it's leaked into the booster. A bad booster would also account for the extra pedal travel.
Dave
People who say it can't be done should not interrupt the person doing it.
84 Mustang GT (Great car to lose your license with, I recommend it for those trying to do so)
74 Ranchero (429, c6, Currie enterprises 9" w/Mickey Thompson cheater slicks, 1970 Torino shaker hood scoop)
82 Bronco (Canadian truck, kilometer speedo, dual batteries, hi-output heater, dual factory block heaters/etc)
78 Bronco (400, 33" Fun Countries, fastback softtop)
79 Bronco (460, 36" Ground Hawgs, frame-off rebuild)
84 Bronco (bone-stock beater)
73 Bronco (I only had it 2 wks before flipping & crushing it.)
76 F-350 (390, 40" Super Swampers, ugly ugly ugly fire-engine green/yellow cab w/faded purple bed)
78 Bronco (460, 38.5" Ground Hawgs, Dana 60's, boxed frame, frame-off rebuild)
86 Bronco (only truck I've ever had fall thru the ice & just plain disappear. no end of hassles from the ins. co.)
91 Bronco (25th anniversary edition, red w/grey leather everything interior, 31x11.5's)
88 Bronco (33x12.5's)
79 Bronco (Current project, 4" lift w/weenie little pizza cutters)
Looking for 78/79 parts, please let me know if you have one you're parting out.
#3 User is offline   michibronc
  • Bronco Maniac
  • PipPipPipPipPip
  • Group: Members
  • Gender:Male
Posted 18 February 2008 - 07:33 AM
Great advice - I'll check it out and get back. Thanks for the reply.
'96 Bronco XL
E4OD
351W
31x10.5's
#4 User is offline   miesk5
  • Use Ford parts, let da ZONE handle ice scrapers
  • Group: Members
  • Gender:Male
  • Interests:Off roading, fishing, beaches, military, breaking metal parts
Posted 18 February 2008 - 11:23 AM
yo!
for that 4WABS:
63 - Pump Motor Triggered but Did Not Run
Possible Causes
· Damaged pump motor.
· Terminal back-out in ABS electronic control module harness connector Pins 17, 29, 37 & 38.
· Open or shorted pump motor relay coil.
· Open contacts in pump motor relay.
· Terminal backout in pump motor 4-way, Pins 1, 2, 3 or 4.
#5 User is offline   bidibronco
  • Bronco Commander
  • Group: Members
  • Gender:Male
  • Interests:My son and wife, engines, 4 wheel drive
Posted 19 February 2008 - 11:29 AM
Hey, I don't think my ABS works properly and I have a super squishy pedal? No lights come one or anything? Someone?
No more Bronco..... :*(
#6 User is offline   BroncoJoe19
  • Supreme Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 19 February 2008 - 12:28 PM
Bidibronco,
I'm gonna jump in here before any one else does and say that a soft pedal may be related to air in the lines, and that they need to be bled.
joe
BroncoJoe19... I am not a professional mechanic, nor an engineer.
One should always obtain professional advice before attempting a repair or modification.
1990 Tan on Black Eddie Bauer - resides in North Jersey
302 with 33's on 15s E4OD Speedometer corrected trans
Auto hubs with manual transfer case snorkel
#7 User is offline   blkwlf
  • It's Only Money, Right?
  • PipPipPip
  • View gallery
  • Group: Members
Posted 20 February 2008 - 06:28 AM
with the extra travel and AWOL brake fluid, its possible that your losing fluid out the back seals of your master cylinder into the booster. that might account for the ABS light but not sure.
95 XLT 5.8, E4OD
stock except K&N, MSD
33x12.5x15 wrangler
turtle wax
Page 1 of 1
Fast Reply
