Jakes85bronco
Ok so I decided to tackle the time consuming job of splicing old burnt/breaking wire's in the engine compartment.
I only had about 13 wires or so, some on the passenger side @ 7. And the rest on the drivers side.
Now i got the ones on the drivers side done. taped up and ready for new plastic tubing. Fired the truck to see if I got the wires atlest good enough to start it. "there were alot of wires that just kinda "stoped" with this like insulation on the tip of the wire"
Ok no I should say I do have a wiring diagram out of a chilton. Though the wires dont match in color so i just kinda
used color matching. Anyways to keep it short the truck wont start since ive done the wires on the drivers side.
When I try to start the truck the starter silinoid just kinda like grinds. So I went a bought a new silinoid. That didnt solve it. If i hold the key to start position the battery starts to boil over. "Like its over charging" And I could see this if the truck was actually turning over. But its not doing I try to jump the silinoid and that didnt work, the starter is new,new plugs, new blaster 2 coil. I need help getting this thing to turn over.
